August 22, 2025, 01:30:45 PM *
Author Topic: Brakes  (Read 1491 times)
strangles
« on: June 06, 2001, 12:00:00 PM »
Would like to known if able to fit LH Torana brake booster on fe ute I plan on using HR front end LH disc and cailipar Thanks
Glenn (Adelaide)
« Reply #1 on: June 08, 2001, 12:00:00 PM »
I am currently fitting up an LC/J booster to my FE sedan. So far so good, drilled the holes in the right spots, cut a hole for the pushrod and had to flatten a bump (cut, flatten, weld, smooth) on the firewall. I have yet to fit up the brake pedal assembly but it work out with the master cylinder only.
Page created in 0.022 seconds with 16 queries.
