August 16, 2025, 04:44:33 AM *
Author Topic: replacement headlight bulbs??  (Read 5190 times)
fc4kiwi
crusin fine in a "59"
« on: April 18, 2004, 09:09:39 AM »
just got rejected for a W.O.F over here in NZ (6 month check) for the headlights! Angry
Im still using the original bulbs (Lucas 42/36)
They have said that the output isn't bright enough on both low & high beam, they have said that I HAVE to update to more powerfull bulbs. Huh
What have you guys overthere done to update?
What watt bulbs can I fit without having to change any of my wiring (just been rewired) and would I have to use a relay due to the fact of drawing more power with brighter bulbs.
FBvisitor
Don't ya' just love an old Holden
« Reply #1 on: April 18, 2004, 09:18:10 AM »
Hi there,
I recently sold my EK wagon which was fitted with sealed beams. They worked a treat and were heaps better than my FB's standard set up. There were no modifications to run these lamps.
Cheers, Jason.
« Reply #2 on: April 18, 2004, 09:19:33 AM »
i never had a problem when using more modern globes with higher output in my FC's during the 80's ,also i think the newer globes actually draw less current whilst delivering brighter glow.
Effie C
Still Lost & Confused
« Reply #3 on: April 18, 2004, 10:37:26 AM »
Unless your car is concourse restoration just change to sealed beam inserts, standard wiring and dipper switch quite capable of handling standard sealed beam units.
Another option is to up grade to H4 inserts and bulbs,would recommend fitting a relay if you go for anything over the 60 / 55W size bulb. The H4 bulbs are available up to 120 / 55W bulbs(Not legal for use on the road in Oz)
See your local auto sparky as they will be able to source higher wattage bulbs or supply the replacements inserts.
Good Luck
John M
PS. What does W.O.F actually stand for,or is it something rude
fcfromscratch
FC - Fantastic Cars
« Reply #4 on: April 18, 2004, 10:49:05 AM »
Hey John,
I can answer that after just spending a month over there...
Warrant Of Fitness.....similar to the roadworthiness systems you guys have in the east....far less complicated over here in the west....
cheers.....Brad
-KIWI-
« Reply #5 on: April 18, 2004, 06:12:30 PM »
w o f also means way of fleecing (a govt program which creates  employment for mechanics,tyre fitters ,panelbeaters , and one of the main reasons why older model cars are so rare !!!!!!!!!)
tony ive got headlamps up here if you want em 60/55w
cheers kiwi (north island version )
fc4kiwi
« Reply #6 on: April 18, 2004, 07:27:46 PM »
thanks for all replys
ive got a set of EH sealbeam headlights in garage, would these fit into FC housings without any drilling,etc
and would they be a improvement over the old FC?
Does anyone know what rating they would be?
Effie C
« Reply #7 on: April 18, 2004, 11:07:08 PM »
Tony
The sealed beams will just drop straight in.
John M
Laszlo
« Reply #8 on: December 16, 2008, 10:02:31 PM »
Hi, I know that's a very old topic.....
"See your local auto sparky as they will be able to source higher wattage bulbs or supply the replacements inserts."
He can't find them........ Where can I get them locally?  I did find an English site : http://www.classic-car-accessories.co.uk/acatalog/12_volt_bulbs.html  &  http://www.classic-car-accessories.co.uk/cgi-bin/sh000397.pl?REFPAGE=http%3a%2f%2fwww%2eclassic%2dcar%2daccessories%2eco%2euk%2facatalog%2f12_volt_bulbs%2ehtml&WD=cls1041&PN=ELECTRICAL_OTHER%2ehtml%23aCLS1041#aCLS1041
Thanks Laszlo
Holden = The Heartbeat of Australia
Laszlo
« Reply #9 on: December 16, 2008, 10:06:33 PM »
For start I'm happy to get the original (?) 50/40 w bulbs !
FX1975
« Reply #10 on: December 17, 2008, 01:59:51 AM »
give these people a try http://www.classicandvintagebulbs.com
