August 26, 2025, 08:18:20 AM *
Author Topic: Rear Brakes Burning up!  (Read 4903 times)
Brett (
« on: May 16, 2001, 12:00:00 PM »
The rear drums on my FC wagon are smelling like they're burning (rubbery sort of smell) and the rear wheels have developed a squeak. The passenger rear is a bit warmer than the driver's side, and sounds loudest squeak wise.
Any ideas what is happening and how to fix it? Haven't had the chance to look properly at it yet, but I think the brake might be locked on slightly?
Only cause I can think of is that I had to slam the brakes to stop last week and since then the problem has started. Thanks
none@unknown.net
« Reply #1 on: May 27, 2001, 12:00:00 PM »
you might ligt to check the handbrake cable isn't jammed. Mine did that once. Mind you, it never works properly, mostly I leave it a LONG way out of adjustment so it never jams.
Regards Richard
r
« Reply #2 on: March 29, 2002, 01:10:47 PM »
If you have brakes from an HD or newer retrofitted, they are self adjusting.  The self adjusters can wind the lining adjustment too far after a hard stop and cause your problem.  Better whip of the drum and inspect the lot in any case if it has overheated.
« Reply #3 on: March 30, 2002, 05:21:02 AM »
Could be a wheel cylinder fault. Because you have applied the brakes so hard the piston has travelled fractionally further than normal, into an area of the cylinder that has corroded. Because the piston has failed to return to its normal position the brake shoes are still being forced into contact with the drum.
If this is the fault you will need to disassemble the wheel cylinder and check its condition. Replacement cylinders can be purchased from brake shops but can be expensive - about $80.00 from memory.
Always pays to replace the brake fluid regularly......
Good Luck.
Page created in 0.028 seconds with 14 queries.
