September 07, 2025, 03:27:58 AM *
Author Topic: vn brake booster  (Read 5407 times)
FATBOY
« on: April 07, 2004, 08:30:12 AM »
has any body used a vn commodore brake booster if so is there any tricks to mounting them up any help will be greatly appreciated
fatboy
0414712441
« Reply #1 on: April 11, 2004, 05:05:12 AM »
Hey Fatboy,
With the booster set up, you will have to decide whether or not you are using an auto or not. If Auto, then the booster will fit, however then you have to look at the pedal set up.
SGO aka George may be able to help you will a VN set up, However I first tried to put VR pedal assembly in and would have to have lengthened the pedals to get it to work... I don't think that changing the pedal length is legal either. Lucky enough for me that th VT booster, and pedal assembly all bolts up together and from starting with them installed in th VT to fitting them into the FE took a total of six hours... The pedal length is perfect onto the ball of your foot. I then cut the frame from the original FE pedals and welded it to the Vt ones, this prevents firewall flexing and when done looked pretty good.
I was then able to go through Hoppers stoppers to get the VT brakes to fit HR drum stubs and with the VN Diff on the back of the car the calipers are again matched to the VT system so had no worries with registration.
Hope this helps
Jason.  Grin
« Last Edit: April 11, 2004, 05:05:58 AM by fevanv6 » Logged
FATBOY
« Reply #2 on: April 19, 2004, 08:19:53 AM »
any chance off a photo. as i am going to use the brake pedals out of the vn statesman
    thanks fatboy
fatboy
0414712441
sgo
« Reply #3 on: April 19, 2004, 09:52:07 AM »
I found a VP pedal a bit short and lengthened it with an FC one. It's not quite right as I think there is a bit too much travel. Back to the drawing board!
« Reply #4 on: April 19, 2004, 11:09:16 PM »
Hey SGO
What car's that accelerator from? Commodore I presume? Looks like just the thing for my car.
sgo
« Reply #5 on: April 20, 2004, 08:37:53 AM »
Yep, its all mostly vp commodore .
THe bracket bolts to a raised base welded to the floor and the top arm is modified to fit!
Digger
Classic not Plastic
« Reply #6 on: April 20, 2004, 01:22:37 PM »
Hey Stinky,
I have used a f##d pedal in my car it fitted in perfect, bolted strait to the floor but I have used the f##d 6 cyl exal cable and it fitted up to a 350 holley,ww2 holden and now to my tripple carbs.
I think it was from a 1991 sedan ??
Steve.
« Reply #7 on: April 20, 2004, 08:33:56 PM »
Cool, thanks Digger, at least I know it's going to be cheap now  Grin.
