September 09, 2025, 07:12:44 PM *
Author Topic: commodore steering column  (Read 6307 times)
FATBOY
« on: April 04, 2004, 08:00:38 AM »
has any one done a late model steering column to fe conversion
fatboy
0414712441
air-chief
« Reply #1 on: April 04, 2004, 08:44:11 AM »
Hey Fatboy
How late are you talking?
I've done a Complete VS column with all switches and the airbag to rear mount rack on my project  FE ute.
Regards a-c Cool
« Reply #2 on: April 05, 2004, 11:32:02 PM »
Nice one a-c.
just an interest question here.
Are the steering shaft/joints using a splined end of D section (with cotter pins like torana) type steering rod ?
« Reply #3 on: April 05, 2004, 11:33:04 PM »
should read...
OR D-section type steering rod
not OF.
FATBOY
« Reply #4 on: April 06, 2004, 05:44:53 AM »
thanks air chief. vn commodore will be the donoe column.also i will be putting the 304 and turbo 700 into the panelvan as well.any hints with heater demister .can i use the one out of the vn.
by the way its a vn stasteman
fatboy
0414712441
air-chief
« Reply #5 on: April 06, 2004, 10:19:20 AM »
Hey Ed.
The steering is using splined ends same as the commodore, I would take some photos for you but the car is now stored as i start work on my other project.
Regards a-c
air-chief
« Reply #6 on: April 06, 2004, 10:23:35 AM »
Hey Fatboy
I don't think you'll fit the VN heater in there, do a seach or scan the older posts and you should find some discussion on this sort of thing. One of the guys was using hairdryers Shocked .
Best of luck with it, keep us informed of your progess.
Cheers a-c
FATBOY
« Reply #7 on: April 07, 2004, 08:23:50 AM »
thanks air chief for your comments what motor and gear box are you running in your car
also regarding the heater iwant to use a late model one any ideas
fatboy
0414712441
air-chief
« Reply #8 on: April 07, 2004, 09:48:36 AM »
Hey Fatboy
I've got an Ecotec V6 and auto box from my  VS  donor car for it. I've had most of the stuff for the build for a couple of years but I keep starting new projects and this one gets pushed to the back of the garage.
Talk to you tomorrow.
Cheers a-c
« Reply #9 on: April 08, 2004, 10:23:20 PM »
Hi Fatboy,
I have used the complete Vt Commodore steering column as well as VX indicator stalks.
The column fits after shortening the shaft, so that the spline on the colapsable column still meshes from the top piece to the bottom piece of the column.
I had a tensile bar made up to go from the commodore column to torana rack.
As for the heater/demister I mounted the unit behind the seats and then ducted the pipes to the front of the vehicle under the centre console.
Have a look at the thread Something old, something new for pictures and the starphoto site.
Jason.
« Reply #10 on: April 08, 2004, 10:30:41 PM »
wow thats interesting Jas,
I assumed you used Commodore rear mount rack.
smithy
yeah its purple !
« Reply #11 on: April 08, 2004, 10:40:58 PM »
hi fatboy,
cant help with the commodore steering but as far as heaters go, i have used the heater from a 60 series landcruiser. they used a small flatish heater mounted beneath the drivers seat to heat the passengers in the back. they work very well, i then had a shroud made up from aluminium (you could just use tin) with holes the right diameter for the demister ducts  around 35mm dia and another couple larger for piping for driver and passenger feet.
i ended up grabbing a couple of old vacuum cleaner nozzles, the flat ones used for fabric and stuff as my demister ducts everything is the right size and can be fit anywhere really. mine is tucked up beneath the dash.
send me a pm and i can foward you some photos of the heater.
good luck
dean
Page created in 0.073 seconds with 16 queries.
