July 14, 2025, 06:44:45 PM *
Pages: [1] 2 3 4   Go Down
Author Topic: Streetneats FC Ute  (Read 37610 times)
streetneat
« on: February 19, 2004, 08:59:14 PM »
Hey all... Here are some pics of the FC ute.. This was built as  tribute Ute to the neighbours FC Ute... They think I'm nuts but there is no suprises there....
« Last Edit: February 23, 2004, 12:37:45 AM by streetneat » Logged
Cheers streetneat -Andrew
streetneat
« Reply #1 on: February 21, 2004, 08:11:26 PM »
A bit worse for wear. Came with red motor (stuffed) and five speed (alloy case - did not use). HR front and rear ends... all there mostly but in poor condition . Purchase price $1200 from wreckers...
streetneat
« Reply #2 on: February 21, 2004, 08:16:42 PM »
Here you can see with the tailgate down it has had a very hard life... the tailgate was so bent it had some wood and packers to give a level (?) surface.. Had been used as a motor bike carrying Ute...
streetneat
« Reply #3 on: February 21, 2004, 08:20:49 PM »
With tailgate up it looks solid enough -but was very badly damaged and full of bog...
streetneat
« Reply #4 on: February 21, 2004, 08:25:20 PM »
The right side was no better than the left.....
streetneat
« Reply #5 on: February 21, 2004, 08:29:24 PM »
Lovely interior shot... came with no seats  but plenty  of rust. Note crappy trans tunnel...All what you see here was entirely scrapped.
streetneat
« Reply #6 on: February 21, 2004, 08:33:21 PM »
Beautiful engine bay... With out the engine and box... This ute had just been through a flood Engine was stuffed ....
streetneat
« Reply #7 on: February 21, 2004, 08:40:44 PM »
This tail gate was repaired as a bet that I couldnt.... Should not have risen to the bait....Took 472 heat shrinks and a whole three days to get right. I unpicked the frame work and repaired everything.... then welded it all back together. Here I am trail fitting it to make sure it all was straight and happy...
streetneat
« Reply #8 on: February 21, 2004, 08:45:18 PM »
Here  you can see I had started to remove rust from the sill and the 1/4 panel... It got much  much worse than this. Also I started cutting a sedan door to suit (note frame removed). This door was not used in the end .. to much rust ...
« Last Edit: February 23, 2004, 12:39:32 AM by streetneat » Logged
streetneat
« Reply #9 on: February 21, 2004, 08:50:48 PM »
Harold is peering through waiting for me to push it inside so he can steer it... Note the sill section I have cut out of a sedan wreck ...Nothing is wasted here...This was ultimately oxy welded in... Repairs to the rest of the inner sill have been effected already .
streetneat
« Reply #10 on: February 21, 2004, 09:00:30 PM »
New tailgate skin fitted. Note door on left side even though its the same colour as the one in previous shots I went to Dalby and bought this one. It was burried 6" in the black soil and was not rusty! Amazing... .Also the sill in the back you can see was a repro one that was only good for small sections.... Tyre door was not used ...I ended up buyng a very good 'Glass one... I am glad I did as it is always full of water and crud now its on the road...
streetneat
« Reply #11 on: February 21, 2004, 09:08:07 PM »
Ready for sand blasters. Subframe and everything else removed except for diff... Jockey wheel made up to support the front...
streetneat
« Reply #12 on: February 21, 2004, 09:11:56 PM »
Another view ... Ute looked pretty solid at this stage.. I had done some repairs but decided it was too hard working around all the rust...
streetneat
« Reply #13 on: February 21, 2004, 09:23:45 PM »
Back from blasters.... Mounted on body pallet for ease of shifting...Drum of steel bits is for counter balance
« Last Edit: February 23, 2004, 12:40:59 AM by streetneat » Logged
streetneat
« Reply #14 on: February 21, 2004, 09:30:20 PM »
Some repairs started again and holes in fire wall filled.
streetneat
« Reply #15 on: February 21, 2004, 09:34:18 PM »
Another view...Although you can see the mig in the pic - I mostly use the oxy.....
streetneat
« Reply #16 on: February 21, 2004, 09:39:52 PM »
Here you can see the WB Ute trans tunnel ready for trail fitting. This is oxy hammer welded into position . A nice sized tunnel and is the most common way I modify most cars using a HQ - WB trans tunnel. I sit it over the floor and mark out where to cut... This is a two person operation and most avoid me when they see I am about to do this....Wife normally helps with this one . I have her trained in this ... She gets under the car with a dolly and a bucket of water to cool the dolly down... Complains of burns but sticks with it any how.... She's great...
streetneat
« Reply #17 on: February 21, 2004, 09:43:37 PM »
This is where it gets really scary... That is the entire rear of the floor removed... note self draining ability in these old utes....
streetneat
« Reply #18 on: February 21, 2004, 09:50:03 PM »
Here you can see the rust repairs I have done to the door pillar and sill on the front . floor is ready to be dropped out
« Last Edit: February 23, 2004, 12:43:19 AM by streetneat » Logged
streetneat
« Reply #19 on: February 21, 2004, 09:55:12 PM »
Here is the view from within ...rust as far as the eye can see...
Pages: [1] 2 3 4   Go Up
Page created in 0.045 seconds with 18 queries.
