August 30, 2025, 07:15:04 AM *
Author Topic: Steering Column length !  (Read 3315 times)
Kermit
« on: January 11, 2004, 12:22:52 PM »
Can anyone tell me how far the "Standard FC Steering Wheel" should be away from the dashboard, as I believe mine is not standard and is far to close to me, can someone give me a measurement and two reference points to go by.
Many Thanks
Mick
robbzfc58
Gone but not forgotten.
« Reply #1 on: January 11, 2004, 12:37:56 PM »
hey  mick  if it looks & feels too close, its probly fc
ill get measurements for you tomorrow if no body else does
                    cheers trev
robbzfc58
« Reply #2 on: January 11, 2004, 01:25:00 PM »
Mick,
I remember looking at your car and I'm sure it's FC.
Here's a picture from when it was for sale, and it looks like FC to me. Bring it to the meeting on Tuesday and you can find out for sure.
« Last Edit: January 11, 2004, 01:25:24 PM by craiga » Logged
COL58FE
FE225
« Reply #3 on: January 11, 2004, 02:17:52 PM »
hi just-mick,i to thought i was going to have that problem,but someone already changed it to ek which are shorter.only problem is if you have long leg's as i do they will spread like an eagle as you drive,because with the standard wheel it line's up and come's down between ya knee's.(close to ya) or (away and spread like an eagle) both not comfy but that's the choice.about 150mm shorter than fe/fc from bottem of dash mount.sorry i can't recall the length of the fe/fc colum though.hope it help's ;)COL58FE Cool
Kermit
« Reply #4 on: January 11, 2004, 07:00:16 PM »
Craig,
Cant bring to meeting as 2 doors off at the moment due to "rusty the FC wrecker". I know from the FC's in my youth that the wheel is out quite some way from the dash, but this one does seem "way out" and a couple of people "FJ + FB drivers" have commented the same + in my non mechanical mind i thought that as its had a "HR" front end put in maybe something has been changed.
Rgds
Mick
robbzfc58
« Reply #5 on: January 11, 2004, 10:48:00 PM »
mick   if you measure from the bracket on the column (the 1 that fixes it to the under side of dash) along column to back of steering wheel, you should get figure of approx 360mm if its fc
             hope it makes sense
                     trev
robbzfc58
Kermit
« Reply #6 on: January 12, 2004, 07:03:02 AM »
Thanks Trev,
for your help
Rgds
Mick
Kermit
« Reply #7 on: January 12, 2004, 10:22:33 AM »
Trev,
My measurements are exact same as you gave me. I will never listen to an FJ or FB driver again
Rgds
Mick
robbzfc58
« Reply #8 on: January 12, 2004, 11:20:45 AM »
careful  mick...im an fb owner too
          Grin
robbzfc58
Kermit
« Reply #9 on: January 12, 2004, 11:27:28 AM »
Did i say "never" because you should "never say never"
Rgds
Mick  Grin
Page created in 0.046 seconds with 16 queries.
