July 17, 2025, 05:33:01 AM *
Author Topic: XU1 MANIFOLD ( Which Hole )  (Read 4114 times)
Blown_FC
« on: December 16, 2003, 04:30:47 AM »
I have a factory HOLDEN XU1 ( Triple Stromberg CD ) manifold, and need to know what all the holes do ?
There are a number of threaded bolt holds at the ends and on the sides of the manifold.
I know one of them is for Vacuum, but the others were all plugged up when I bought the manifold.
Obviously they must be used for something ?
I've blown through the holes and sussed out were the chambers go, but need to know what function they perform....it looks almost as if there is a water chamber in it Huh?
Any help please...pics are good too !
Mark
mike
« Reply #1 on: December 17, 2003, 12:35:47 AM »
Here's a couple of pics, I hope they help, this is the 1.5CD carbs. By memory the 1.75 had the water inlet and outlet deleted from the manifold,
regards mike.
Blown_FC
« Reply #2 on: December 17, 2003, 12:45:01 AM »
Mike....thanks heaps for that pic.....it helps quite a bit....still need a close up of the other vacuum holes, but the water holes are very clear, and helps solve most of the query.
Thanks heaps for helping me out ,  it's much appreciated.
Mark Hughes
mike
« Reply #3 on: December 17, 2003, 04:16:35 AM »
You got me curious so I had to go out to the shed to check my carbies, the original manifold has the 2 water fittings front and rear, then the 2 fittings to go to the pcv valve and where I have arrowed there is 2 holes, one top and one almost directly underneath these are plugged from the factory, not sure what these were for if anything,
regards mike.
Blown_FC
« Reply #4 on: December 17, 2003, 04:53:48 AM »
Mike....thanks heaps...I printed out the 1st pic you posted, but only the left pic printed out, but now I can see the close up of the manifold vacuum holes......helps alot to open your eyes hey ?
The 2 holes you talk about that are plugged from the factory, helps out too...as if they were plugged from the factory, then that's how mine will be !
Looks like I may have to find a thermostat housing than has the 2 water pipes off hanging off the side of it, as the one I have is jsut a plain old one outlet type.
Do you knwo where I can get a thermostat housing to suit the XU1 manifold Huh?
Thanks again Mike...you've been a big help.
Mark
Dr_Terry
« Reply #5 on: December 17, 2003, 12:34:38 PM »
Hi BlownFC.
You have me a bit confused about your thermostat housing.
EH & HD lower housings have no outlets & all housings after that have 2 outlets. You say yours has 1.
All XU-1 lower thermostat housings are the same as standard for those years (1970 to 1973).
Can you post a photo.
Regards.
Dr Terry.
Blown_FC
« Reply #6 on: December 17, 2003, 11:58:02 PM »
Dr Terry, you may be right.......I am only going off my memory of it, as it's off car and tucked away under a bench somewhere...I'll dig it out and have a more deetailed look.....cheers
Mark
