August 28, 2025, 09:28:28 AM *
Author Topic: LSD Centre  (Read 1910 times)
Bates
0413 773 747
« on: September 18, 2003, 09:31:24 AM »
Hi
I,ve got two Limited Slip diff centres to suit Fe up to Hr. One is perfect condition other is decent but has rust stains on gears. Both are 3.3 ratio. Asking $200 and $120 for the other.
If interested please ring 0413 773 747 or email me phone will be quicker
thanks
Bates
KEN
« Reply #1 on: September 18, 2003, 10:11:52 AM »
G'DAY BATES
I AM INTERESTED IN THE GOOD CENTRE,BUT WILL IT FIT INTO A STOCK FE BANJO ?
IT WAS GETTING A BIT LATE TO RING, SO I WILL RING YOU ON THURSDAY MORNING OR IF I FORGET YOU COULD RING ME ON 0404461260
IM ON THE CENTRAL COAST N.S.W.
                                                      THANKS......KEN
HARKO
« Reply #2 on: September 18, 2003, 10:39:42 AM »
A limited slip diff centre housing will have a threaded nut on the inside bottom of the housing,
Rather than placing the centre over the stud as you would FE FC Type , You will have to weld into the housing a nut so you screw a bolt in through the housing rather than a nut on the stud.
Not sure if that makes sence , I correctly standed     Smiley
