August 28, 2025, 06:34:46 AM *
Author Topic: Timing Cover Alignment Tool  (Read 2440 times)
Jolls
« on: May 09, 2024, 08:25:00 AM »
Hi Team,
Is the timing cover alignment tool something worth making/buying or is it just a nice to have.
I didn't use one on my last grey motor rebuild (in the 80s); but I'm no longer 17 so I'm not doing the rebuild on a shoestring budget under a tarp the driveway.
Jolls
Cheers n Beers
Jolls
« Reply #1 on: May 09, 2024, 09:19:35 AM »
Craig,
I've got one, but don't use it often.  Instead, I use the harmonic balancer as the alignment tool: with the timing cover loose, drive the balancer onto the crank just far enough to engage the seal, then tighten the screws.
grey nomad
« Reply #2 on: May 09, 2024, 09:39:09 AM »
Making sure the top screw is clear of the water pump…..just saying ??
Jolls
« Reply #3 on: May 09, 2024, 10:19:30 AM »
Craig,
Thanks Rob - that's the method I used before. Keep it simple, stupid!
Cheers n Beers
Jolls
Jolls
« Reply #4 on: May 09, 2024, 10:21:17 AM »
Thanks - good reminder!
Cheers n Beers
Jolls
my8thholden
« Reply #5 on: May 10, 2024, 08:23:31 AM »
use a double lip seal , pack some high temp grease between lips ..if inner lip seals well the outer lip may overheat and burn , grease will go someway to stopping that , the inner lip will get oil on it if all correct
Jolls
« Reply #6 on: May 10, 2024, 11:23:09 AM »
Thanks Vern,
I will ensure I grab one with a double lip.
Cheers n Beers
Jolls
