August 23, 2025, 10:38:02 AM *
Author Topic: FC Ute Jack  (Read 8210 times)
Jolls
« on: December 30, 2023, 09:13:31 PM »
Hi Team
Been looking for an original jack for the ute. I came across two versions supposedly off Holdens of the era. Can anyone tell me which one is the right one; or are they both incorrect?
Cheers n Beers
Jolls
Cheers n Beers
Jolls
Fraze
« Reply #1 on: December 31, 2023, 07:23:34 AM »
The original ute jack was a screw type bottle jack, not hydraulic
« Reply #2 on: January 01, 2024, 01:16:31 PM »
I agree. Two stage screw I believe, though the later three stage seem virtually identical and stronger. Passenger cars tended to have the scissor jacks with ratcheting lever handle. The commercial bodies were minus the  B-pillar jacking bracket and used the 2 stage screw bottle jack.
The second old hydraulic jack is quite familiar though.
Jolls
« Reply #3 on: January 01, 2024, 02:19:00 PM »
Thanks guys, screw type it is then. Will start searching!
Cheers n Beers
Jolls
Cheers n Beers
Jolls
FE_UTE
« Reply #4 on: January 02, 2024, 09:15:45 PM »
Jolls ...this is the jack you should look for its out of my FE Ute
Cheers Gary
Spinner
« Reply #5 on: January 03, 2024, 08:48:16 AM »
Jolls,
Check this out.
https://www.gumtree.com.au/s-ad/corio/other-parts-accessories/-holden-jack-/1319916544
« Reply #6 on: January 03, 2024, 10:31:54 AM »
Plenty of these jacks at swap meets, half that price, or less.
Jolls
« Reply #7 on: January 04, 2024, 02:51:13 PM »
Thansk for the head up!
Cheers n Beers
Jolls
Jolls
« Reply #8 on: January 04, 2024, 02:51:55 PM »
Cheers Gary
Thanks Gary - that is gold. I knowexacrly what I am after now. Cheers
Cheers n Beers
Jolls
« Reply #9 on: January 04, 2024, 08:30:56 PM »
It is indeed gold. Well, orange, anyway. Grin
my8thholden
« Reply #10 on: January 05, 2024, 06:43:53 AM »
Jolls ..different types here , you can just see it on the Ebay one ,the original had the fitting right under the screw on the base line so you can put the square head of the handle in there to position the jack under the car and then pull it out when finished  .if you go for one like the orange one from WA should come with pair of knee pads ..
my8thholden
« Reply #11 on: January 05, 2024, 06:53:19 AM »
Those old screw jacks if damaged , ie vehicle fell off jack , say a FE ute loaded with cases of beer and buckets of ice and buckets of prawns ..or used on a Kenworth ..just try before you buy ..now serious ..if the internal casting for the thread has been bent out of alignment , you cant get at it , and on full extesion looks to be leaning , not square to body ..when you go to use with a load as you wind up , cause things dont fall over when not extended , you will hit a tight spot and have to turn into Superman to wind the bugger ..if at all ..guess what taught me to swear ? ..Vern ..
Jolls
« Reply #12 on: January 05, 2024, 06:08:46 PM »
I have a very funny picture in my mind Vern. I will definitey check. I don't know how many of these things I've turfed over the years and now I want one. Mrs Jolls gets the shits when I "hoard" things. I guess this is another time when I can tell her if only I kept it for another ten years or so!
Jolls
Cheers n Beers
Jolls
Jolls
« Reply #13 on: January 08, 2024, 11:43:32 AM »
Jack has been sorted, young fella picked one up in town this morning.
Found the correct decal on ePAy
It works well; however, the paint is completely gone and so I don't have anything to match the paint to.
I know it's being anal and the colour of the paint won't make the jack work any better; however, if I'm going to get some paint I may as well try to match it as best I can.
Is there a particular paint code for the shade of "orange"?
Cheers n Beers
Jolls
Cheers n Beers
Jolls
« Reply #14 on: January 08, 2024, 05:18:33 PM »
That could be a later HQ commercial jack
Sent from my SM-G781B using Tapatalk
« Reply #15 on: January 08, 2024, 05:19:22 PM »
Is there a code stamped bottom or side?
Jolls
« Reply #16 on: January 08, 2024, 05:26:08 PM »
I won't be able to pick it up until tomorrow when I head into town to get a wheel alignment for our truck. It is a two stage jack and appears to be correct from the pictures; however, I wasn't able to look it over closely and the owner had no idea. Son 3 ensured that it worked and was not bent/threads not damaged in any way. Will let you know tomorrow.
Cheers n Beers
Jolls
Cheers n Beers
Jolls
Jolls
« Reply #17 on: January 09, 2024, 09:11:12 AM »
There are no numbers on the jack at all. Under the grime I was able to identify some orange paint so it appears to be the correct jack. It is really grubby on the exterior but in good working order. Need to see how it cleans up to see if I can use it as a means to match the paint.
Jolls
Cheers n Beers
Jolls
Brad
« Reply #18 on: January 29, 2024, 09:48:15 PM »
   I've seen them in grey like the motor ??
        But that could be fb or ek.
        Brad.
grey nomad
« Reply #19 on: January 30, 2024, 11:25:44 AM »
May be corrected here but the orange jack as shown above is fx- fj as it has no bracket for lining up.  AL.
Page created in 0.043 seconds with 19 queries.
