Jolls
Offline
« Reply #8 on: August 27, 2024, 12:32:02 PM » |
Thanks Rob,
Poorly explained; the resistance is on the sender side of the pins to B(-). The testing was executed as such:
Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal, to battery (-), with fuel gauge case connected to battery (-) = needle pointing to left hand dot (Empty) Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal to 15 ohm resistance, lead from resistance, battery (-), with fuel gauge case connected to battery (-) = needle pointing to left hand dot (Empty) Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal to 30 ohm resistance, lead from resistance, battery (-), with fuel gauge case connected to battery (-) = needle pointing to left hand dot (Empty) Battery (+), lead to fuel gauge B+ terminal, sender terminal disconnected from battery (-), with fuel gauge case connected to battery (-) = full deflection to the right (Full)
My thoughts are that there is a short between the sender pin and the coil. To test my theory I borrowed two known working gauges from a friend. The results I have from these gauges are:
Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal, to battery (-), with fuel gauge case connected to battery (-). Reads Left Hand Dot (Empty) Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal to 15 ohm resistance, lead from resistance, battery (-), with fuel gauge case connected to battery (-) = needle to 1/2 (gauge 1) and 3/4 (gauge 2) Battery (+), lead to fuel gauge B+ terminal, lead from fuel gauge sender terminal to 30 ohm resistance, lead from resistance, battery (-), with fuel gauge case connected to battery (-) = needle at full defelction (Full) Battery (+), lead to fuel gauge B+ terminal sender terminal disconnected from battery (-), with fuel gauge case connected to battery (-) full deflection to the right
I'm not sure what the odds of pulling three gauges with the same/similar fault are, but I expect about as much as winning lotto.
I have done a deal with my mate to brew up some All Grain Beer and loan him my tap setup for a function he has coming up in exchange for the more accurate of the two working gauges. I will keep the others as spares and get one of them down to GaugeWorks if the one I have now falls over. I had our local signwriter make up some stickers to refurb the glass but I am thinking that it may be better to stick the surrounds on the back of the glass and use the airbrush to bring it the E, F and FUEL symbols back to life. I have a couple of sets of glass to play with so we will see how it turns out.
Thanks for your input Rob, appreciate it. I thought I was going a bit mad for a while there. So another problem solved - next issue to deal with is king pins!
Cheers n Beers
