August 20, 2025, 11:55:33 PM *
Author Topic: FC brake drums  (Read 4518 times)
fc25250
« on: July 26, 2022, 06:54:27 PM »
Realise it’s an old well gone over topic but has any definitive means of overcoming this perennial problem been reached ? My FC wagons 9” drums are all run out and from what I have read EH ones will do the trick if machined to prevent fouling with the FC back plate.
I have a number of FC drums and their construction is rather lightweight compared to the heavier more solid EH ones.
EH ones to me seems to be easiest way rather than altering all the other components.
Any suggestions as well as best drums to get me back up n running much appreciated.
« Reply #1 on: July 26, 2022, 07:23:02 PM »
Probably easier to machine the drums for clearance, but alternatively you can change brake shoes and backing plates to FB EK. Then the EJ drums go straight on.
« Reply #2 on: July 26, 2022, 09:51:08 PM »
For the front brakes, yes.  I don't know if FB-EK rear backing plates and drums would line up correctly on an FC rear axle.
« Reply #3 on: November 04, 2024, 05:50:15 PM »
Point taken Rob. The alternative being to go and swap an EH HR or even LC UC rear axle housing under the back.
Regarding the front brakes, rather than mucking around with machining drums, another alternative appears to be bolting on EJ EH backing plates and brakes. This also requires using the EJ HD kingpin steering arms as you pointed out on the FB EK forum. I’m still wondering though, if the wider HD kingpin front brakes will bolt to the  FE EK spindles.
