August 30, 2025, 12:16:40 PM *
Author Topic: ute tailgate rubber bushes  (Read 1807 times)
Wasim
« on: October 16, 2021, 10:52:14 AM »
What are the suggestions to replace the rubber bushes that are on the metal stays that hold the tailgate at horizontal when open??
Thanks in advance
South Australia
REDMR2RED
FC Ute's d'best
« Reply #1 on: October 16, 2021, 02:56:37 PM »
I turned some up on a lathe out of rubber block, using a 4" angle grinder (as a lathe tool) to remove excess rubber.  Then cut the rods, fitted the rubber cushion/slides and welded the rods back up.  Filed and re-painted you can't tell the difference.
1959 FC Holden Ute
« Reply #2 on: October 16, 2021, 06:00:33 PM »
Rubber door stops, from Bunnings. Put a bolt through them, put it into a drill, and use a file to machine them down. Sandpaper smooth, still in the drill. Remove bolt, slit rubber, put onto rattle rods and superglue the slit.
Wasim
« Reply #3 on: October 17, 2021, 11:29:11 AM »
Thank you - Great suggestions
South Australia
