August 31, 2025, 01:12:58 AM *
Author Topic: Inside of front guard coating  (Read 2511 times)
texmorton
« on: September 14, 2021, 11:41:08 AM »
G'day again,
I have done a quick search and nothing came up re: what was the factory finish inside the front guards; painted body colour, body deadener or chassis black?? Thanks, Al
Trevor_B
Melbourne VIC
« Reply #1 on: September 14, 2021, 05:03:49 PM »
Hi Al,
While you are considering the correct finish to use, here is something else to think about...
If your guards have been worked a lot, say to remove rust and/or dints, the metal can be thinner than factory which can cause starring in the paintwork from stones being thrown up by the tyres. I have seen this on a car that had been resprayed on months beforehand.
I guess this would be less of an issue if you never travel on gravel roads but still a remote chance on sealed roads too.
I decided to use dynamat type material directly above the tyre just in case...
Just a thought.
Trevor_B
« Reply #2 on: September 14, 2021, 09:18:53 PM »
The FC specification issued by GMH states that either primer followed by underbody black (375-1646) or primer followed by dipping black (366-1690) is the required finish.
So, underbody black or chassis black would suffice.
« Reply #3 on: September 14, 2021, 10:06:19 PM »
Stone guard or body schutz will reduce any stone impact
texmorton
« Reply #4 on: September 15, 2021, 08:54:18 AM »
Awesome, thanks fellas. I reckon I will go for stone guard then which will be a slight departure from original but sounds like the way to go. Al
DougT
« Reply #5 on: September 16, 2021, 08:40:21 AM »
Original isn't always the best, evidenced by the amount of rust that has been cut out of old Holdens over the years.
Page created in 0.035 seconds with 16 queries.
