August 20, 2025, 12:25:48 AM *
Author Topic: Old roof deadener  (Read 7813 times)
Laszlo
« on: August 18, 2021, 06:47:46 PM »
G'day guys  !
I need an advice how can I get rid off the old roof deadener completely.
So far I cleaned up with a chisel, most of them came off.
After I used a wire wheel on a drill, I tried the paint and rust stripping wheels and an orbital sander too. But still not good enough to stick the new deadener  and self sticking heat mats from Car builders.
Feel and looks reasonably clean, but when I  do the masking tape probe still a lots of little piece sticking to the tape.
So not clean enough. They definitely done a good job 65 years ago.
I thought maybe I just paint over and hopefully  all the little leftover bits will stick to the roof.
Laszlo
Holden = The Heartbeat of Australia
Laszlo
« Reply #1 on: August 18, 2021, 06:51:19 PM »
The tools and the half finished product
Sent from my SM-G965F using Tapatalk
« Reply #2 on: August 18, 2021, 08:05:04 PM »
Laszlo,
The sound deadener is "bituminous paper": essentially tar-soaked cardboard.
You would need mineral turpentine or similar solvent to remove the residue (and I hope the interior is out of the car).
Another idea is to warm it up with a hot-air gun, gently, to avoid blistering the paint (or even park the car in the sun) and use a paint scraper.  Then you'll still need to use turps for the final clean.  Then wire brush, then Deoxidine, then a thin coat of epoxy primer, and the new sound deadener will stick to the roof like the proverbial s... to a blanket.
Laszlo
« Reply #3 on: August 18, 2021, 09:48:07 PM »
Thanks Rob !
Big help !
Yes everything is out from the car. Seats , door trims, carpet etc..
Cheers : Laszlo
« Reply #4 on: August 19, 2021, 08:59:01 AM »
Yes, a hot air gun works really well, the bitumen has a fairly low melting point and will scrape off easily once heated.
Laszlo
« Reply #5 on: August 19, 2021, 11:26:31 AM »
Thanks Ken !
I think I prefer the heat treatment too.
Laszlo
camxsmith
« Reply #6 on: August 19, 2021, 06:20:25 PM »
I to agree with the heat treatment process
Laszlo
« Reply #7 on: August 19, 2021, 09:44:32 PM »
Tonight I bought some acetone from Bunnings just for try it. Done not much at all.  The forecast for the weekend : sunny ! ( Queensland : )  I will try the heat treatment.
Laszlo
« Reply #8 on: August 20, 2021, 07:04:17 AM »
Lazlo ..Its bitumen based ,so after heat/ scraping clean up with kerosene , or diesel , kero is better cause you will probably have to clean up the diesel residue . Acetone will only harden it ...keep well Vern ..
Laszlo
« Reply #9 on: August 20, 2021, 11:09:43 AM »
You are right Vern. After I tried the acetone and started scraping the bitumen was harder but came off (broken off) a bit easier with the paint scrapper.
I will try the kero.
I cleaned up so far 25 % of the roof 75% still to go....
Thanks for all the advice  guys , big  help !
Cheers: Laszlo
Laszlo
« Reply #10 on: August 23, 2021, 07:30:24 AM »
One more question:
Originally the rear parcel shelf had any vinyl cover on  or just was a painted metal shelf ?
Laszlo
« Reply #11 on: August 23, 2021, 08:03:58 AM »
Vinyl on card Laszlo
Laszlo
« Reply #12 on: August 23, 2021, 09:10:33 AM »
Thanks Errol  !
Looks like mine was already modified,  when I  removed the vinyl I have a metal shelf, like the dash"board". And the vinyl was tucked under the window rubber seal.
I think I will clean it up properly and just paint over the metal.
Laszlo
Laszlo
« Reply #13 on: August 23, 2021, 09:49:54 AM »
....or originally the card with the vinyl was just sitting on the metal base....(?)
« Reply #14 on: August 23, 2021, 02:26:05 PM »
Glued under the window seal as you say Laszlo
« Reply #15 on: August 24, 2021, 08:04:23 AM »
Lazlo ..The parcel shelf was primed when the body was ,then finished matt black. I got a embossed sheet from motor trimmers , cut a paper pattern , then cut the sheet and put in with contact adhesive ..its black , my trim is fall red/black ..its about 2mm thick , like a heavy cardboard ,has a pattern in it like leather grain .with the venetians its not really a visible item. .
cheers .Vern ..
Laszlo
« Reply #16 on: August 24, 2021, 10:34:55 PM »
Thanks Vern!
I'm thinking about just painting the parcel shelf with the same matt black like the dashboard. Simple and clean with the two speaker covers.
« Reply #17 on: August 25, 2021, 06:59:40 AM »
yeah why not ,i've seen that and carpet ,wood ,and same vinyl as seats ,depends if you want to be 100% stock original or not ..keep well Vern ..
Laszlo
« Reply #18 on: August 25, 2021, 05:07:08 PM »
Vern my Fe definitely not a⁵ stock any more with the chevy in it.
I just found out today the upholstery guy don't want to do my car hood lining any more,  his got a bad back and don't want to spend that much time in the car at the moment.
He gave me an other upholstery  guy phone number. Beenleigh upholstery (very good reviews). The trouble  he can't book me in before January.
Anybody knows a good trimmer in Brisbane  ?
And next question  : Anybody used the C&G upholstery (eBay store) hoodlining ? They asking $175 for it. Sounds reasonable.
Thanks : Laszlo
Laszlo
« Reply #19 on: August 26, 2021, 10:19:08 AM »
I found a car trimmer in Capalaba "Annvid", they done Fe headlining before. They have good reviews too.
So hopefully they will do a good job.
Cheers  :Laszlo
Page created in 0.021 seconds with 17 queries.
