August 19, 2025, 11:52:22 PM *
Author Topic: Gearbox oil  (Read 4080 times)
JohnBM
« on: May 14, 2021, 03:11:39 PM »
I will be changing the gasket on the gearbox shortly & normally use Castrol oils for engine etc . What do others use , if using Castrol ? There’s a castrol universal 80/90. For manual transmissions . The GMH manual shows straight run mineral oil SAE 90 . I’m probably worrying about nothing . Cheers John .
« Reply #1 on: May 14, 2021, 08:07:14 PM »
Just using gulf western 80/90 with 20% Morey’s heavy duty oil stabiliser.
JohnBM
« Reply #2 on: May 17, 2021, 01:18:52 PM »
Thanks Errol , I see you use Moreys as well , good to see . It seems that using 80/90 oil is the go & whatever brand is a personal choice . Thanks for reply .cheers John.
« Reply #3 on: May 17, 2021, 08:08:12 PM »
Trevor_B
Melbourne VIC
« Reply #4 on: May 18, 2021, 01:35:12 PM »
Hi John,
If you want a direct replacement for the GMH Oil then use Penrite Transoil 90: https://www.penriteoil.com.au/products/transoil-sae-90 It is a straight SAE90 Mineral Oil.
It is important not to use multi grade or friction modified oils in grey gearboxes as they can impact the function of the syncromesh engagement.
Trevor_B
Page created in 0.02 seconds with 16 queries.
