August 22, 2025, 04:27:44 AM *
Author Topic: Oil pressure gauge  (Read 5042 times)
Wookie 66
« on: May 05, 2021, 06:27:29 AM »
Good morning all
Is it possible to retain the original oil warning light and fit an after market oil pressure gauge,
I spy a small plug towards the front of the block that the new gauge fitting will fit
Will that work or do I have use the original sender unit spot? Hope this makes sense
« Reply #1 on: May 05, 2021, 07:43:09 AM »
Usually you just get a tee adapter
Fraze
« Reply #2 on: May 05, 2021, 08:06:02 AM »
The small plug near the fuel pump goes nowhere. When you have an accessory oil filter fitted, the return line is fitted there, to return oil to the sump. For the pressure guage, fit a "T" at the oil pressure sender fitting. Cheers, Fraze
« Reply #3 on: May 05, 2021, 11:50:59 AM »
From memory, that line of slotted-head plugs are on the cam oil feed gallery.
Wookie 66
« Reply #4 on: May 06, 2021, 06:45:21 AM »
Thanks for the info
Where might one get the T adaptor from ?
« Reply #5 on: May 06, 2021, 07:30:38 AM »
Local speed shop
Wookie 66
« Reply #6 on: May 06, 2021, 06:33:51 PM »
Thanks every one all good autobarn had it stock
« Reply #7 on: May 06, 2021, 07:15:49 PM »
Good to know. There may actually be hope for the world yet. Cool
