August 04, 2025, 04:40:40 PM *
Author Topic: 1958 FC Station Sedan Chassis  (Read 5042 times)
THEGURU14
« on: March 25, 2021, 11:22:50 PM »
Hey, just wondering if there are any donor chassis around for my 1958 FC Station Sedan. It’s quite badly rusted near the front doors and on the rear wheel arches. Also if there are any drawings or schematics of the chassis that would be very appreciated.
FireKraka
« Reply #1 on: March 26, 2021, 10:20:19 AM »
Hi Guru if you have a manual it will show you the dimensions of the chassis etc. if you don't have one then maybe someone on here can post for you or I suggest you get one for your own reference.
Neil
THEGURU14
« Reply #2 on: March 26, 2021, 11:28:46 AM »
Thanks Krata, yeah I need to find a manual, either an original or a breakdown one. I’m sure there would be one floating around
« Reply #3 on: March 26, 2021, 05:45:16 PM »
The FC doesn’t have a chassis that unbolt like a chev of the same year does. Everything has to be cut out and repaired. Generally even donor pieces from other cars need a little repair work before they can be used again. The workshop manual shows the chassis details but fitting / making new pieces is generally how it’s done.
I have a workshop manual for sale if you are interested in purchasing one.
THEGURU14
« Reply #4 on: March 26, 2021, 09:30:30 PM »
Cheers man. Yeah that makes sense. As we were tearing her down the chassis turned out better than we thought so yeah cutting it out and repairing is definitely the best way forward. I might enquire about the manual a little later when needed
FireKraka
« Reply #5 on: March 27, 2021, 11:18:51 AM »
HeyGuru are you talking about the front end (subchassis) when you are talking chassis or the strengthening under the floor  Huh I'll take a photo from the manual for you and post it.
Neil
camxsmith
« Reply #6 on: March 28, 2021, 11:27:53 AM »
Im not sure but you can have a look thru these and see if you can find some dimensions Technical and engineering Specifications Documents
THEGURU14
« Reply #7 on: March 28, 2021, 05:11:26 PM »
Neil
Well a little bit of both. The major brace under the floor from the passenger to driver door has rusted away. A few of the floor strengthers are eaten away also, so any photos would be a great help
THEGURU14
« Reply #8 on: March 28, 2021, 05:12:18 PM »
Thanks mate. That last one may be of use. It’s for the FE but it’s very similar
FireKraka
« Reply #9 on: March 29, 2021, 10:45:01 AM »
Hi Guru;
Those pieces are very common to rust out and are available from Rare Spares.
I find it a pain to post photos on here so PM me an email address or mobile phone number and I will send you the photo from the manual of the chassis/floor bracing from the manual.
Neil
« Reply #10 on: March 29, 2021, 04:48:43 PM »
By the looks of your No. 1 body crossmember, you'll most likely have rust holes in the bottoms of the cowl panels also (just inside the lower rear corners of the front guards, where the outer subframe legs bolt on).  While you're at it, take a good look at the front subframe tie member (just to the front of and below the radiator), the lower subframe legs, and the sills.  If you're brave, take a look inside the rear wheel arches, at the bottom front corner where all the sand and mud accumulate.
It may end up being a remove-everything-forward-of-the-firewall repair job.
THEGURU14
« Reply #11 on: March 30, 2021, 03:40:38 AM »
Thanks for the insight mate. You really know your away around that kind of rust. I’ll be sure to check it all over and determine the extent of the rust which will be fun. Thankyou again
« Reply #12 on: March 31, 2021, 08:53:22 PM »
You don't know the half of it mate. Check out Rob's thread here: Found Object
