August 17, 2025, 01:14:18 PM *
Author Topic: Gear lever bearing support (honey pot) WANTED  (Read 1613 times)
abletec
« on: May 21, 2020, 03:52:44 PM »
Gear lever and upper steering column bearing support (honey pot) WANTED for FC. Part number 7409292. Trying to find out how to add a photo.
This is the bell shaped housing behind the steering wheel that the column change lever is attached to.
Also require a steering drag link plug. This is the 1 1/8 threaded plug at both ends of the drag link that has the split pin pass through.
Would need to be sent to Perth.
Thanks.
« Reply #1 on: May 21, 2020, 06:00:02 PM »
The drag link plug is a pretty universal part.  Any Holden from FX to EH will do.  I've got a few, but you should be able to find one in Perth.
Page created in 0.021 seconds with 18 queries.
