August 03, 2025, 03:05:11 AM *
Pages: 1 ... 11 12 [13]   Go Down
Author Topic: NEW PROJECT FC UTE  (Read 102442 times)
Mal W
« Reply #240 on: September 25, 2024, 02:04:57 PM »
Next was to finish of the welding on the front subframe.
Started with the strengthening plates on the underside of the subframe.
Once that was done I made a gusset for the back corners of the subframe
Also I ended up changing the lower radiator mounts to drop the radiator Dow a bit giving me more clearance to the bonnet lock panel.
Next I just have to remake the top radiator bracket.
Malcolm WHITTAKER
Gman
« Reply #241 on: September 25, 2024, 03:17:04 PM »
Geez, looking good!!! You are quite the master with metal!!
Mal W
« Reply #242 on: September 25, 2024, 06:36:57 PM »
Last bit of rust to do has been done, RH front guard needed a new top, rear lower and headlight area.
Inner and outer both needed rebuilding
Corner all done
Lower section wasn’t to bad
Headlight area needed a little bit more work
Then to tidy up the inside bolt edge by adding a return lip
Now I know these aren’t everyone’s cup of tea but I like them
I changed the front and back of the insert panel so it lined up with the angles of the lower guard section’s
Malcolm WHITTAKER
Mal W
« Reply #243 on: September 25, 2024, 06:57:53 PM »
Recently I had the opportunity to purchase the wheels I originally wanted but couldn’t get at the time.
Weld wheels, fronts 15x5, rear 15x10.
Malcolm WHITTAKER
Jolls
« Reply #244 on: September 25, 2024, 07:06:18 PM »
Hi Malcolm.
A mountain of work there and the ute is truly a one off!  It doesn't matter what anyone thinks about the modification but you; it's your ute!
I'm about to start work on the body of my ute. Nothing drastic just repairs to bring it back to life; but I sure wish I had some of your metalworking skills.
Looking forward to seeing the end result.
Jolls
Cheers n Beers
Jolls
« Reply #245 on: September 26, 2024, 07:06:08 AM »
Thanks for the update Mal ...certainly a credit to you , I just love that " FAT " rubber , it just wouldn't be right 6.40 x 13  ...Vern
« Reply #246 on: September 26, 2024, 06:25:25 PM »
Fantastic Mal. Thanks for the update.
Mal W
« Reply #247 on: December 08, 2024, 09:43:47 PM »
Been busy in the shed now for a while and some good progress made.
Starting with my bonnet hinges, I wanted something different that wasn’t so big and bulky.
Did a bit of experimenting with a couple of different styles.
A fair bit of trial and error, but got there in the end.
The first one was a modified boot hinge, but just looked to big and couldn’t get a good clearance where needed.
Next was a temp plate of a sissor type version, but that was crap.
A lot of measurements and drawings was done along the way.
What I ended up with is a consealed type hinge with the pivot point and gas ram under the dash.
These hinges I made out of 2 pieces of flat stainless welded together then ground up, sanded and polished.
Firstly I made up a template of the hinge to make sure i was going to have enough clearance where I needed it.
Hinge pivot and gas ram is all fitted up under the dash
Then I clamped the 2 sections together and start welding.
A lot of checking and changing as I go.
Welded together with stainless wire in the mig. Looks crap but got there in the end and nice and strong.
Very happy with how they polished up.
I had to move the bolt location in the bonnet to line up with the hinges.
That part all done. It took a while to get the gas ram position sorted but the bonnet opens and closes nicely.
Malcolm WHITTAKER
Mal W
« Reply #248 on: December 08, 2024, 11:07:34 PM »
Part 2 of the bonnet hinges.
Now the hinges are done I have to make it look like they should be there.
I did a fair bit of modification around the hinge area making a box section around the hinge that incorporates a seal around the hinge and a trim around the top where the hinge comes out.
Still in the process of making the hinge seal and top trim.
Malcolm WHITTAKER
« Reply #249 on: December 09, 2024, 07:44:48 AM »
Great to see an update Mal. Amazing work as ever.
« Reply #250 on: December 10, 2024, 12:39:08 PM »
Those hinges are a work of art!
It'd be interesting to get some time frames on some of the work pieces.
Mal W
« Reply #251 on: December 17, 2024, 09:06:08 PM »
Finally got the bonnet hinge surrounds made.
I made these out of stainless as well and then just polished.
Now to do a few finishing off bits on the subframe and I can finish off the bonnet and front guards.
Malcolm WHITTAKER
« Reply #252 on: December 18, 2024, 06:53:01 AM »
Thanks for bring us up to date Malcolm. Very clever stuff.
Stewy
sa-club
Jeff Stewart
« Reply #253 on: December 18, 2024, 09:02:22 PM »
Spectacular work as always Mal, This sure is a work of art.
Cheers Stewy  Cool
blacky
« Reply #254 on: January 21, 2025, 01:49:13 PM »
 That is next level cool Mal, how do you go sealing them up regarding water/heat/noise ingress into the cab ?
 You never fail to impress with your innovative ideas
Mal W
« Reply #255 on: January 21, 2025, 10:40:40 PM »
Thanks for the comments fellas,
The hinges have an outer rubber seal that goes under the stainless surround, behind that is a very thick and dense underlay type wadding packed into the hinge pocket. Then there is another rubber seal and a retaining bracket.
Inside the hinge pocket at the bottom is a drain hole incase any water does get in.
Hopefully another update will be coming soon.
Malcolm WHITTAKER
blacky
« Reply #256 on: July 30, 2025, 03:34:28 PM »
 Any updates Mal HuhHuhHuhHuhHuh?
« Reply #257 on: August 01, 2025, 05:26:42 PM »
Yeah !!! come on Mal , need some more engineering master piece revelations , TV is boring ...
« Reply #258 on: August 01, 2025, 09:38:32 PM »
Patience grasshoppers 🙃
Pages: 1 ... 11 12 [13]   Go Up
Page created in 0.041 seconds with 17 queries.
