« Reply #40 on: April 17, 2020, 09:02:24 AM » |
Geez Mal not a lot of floor left there mate  but by the looks of the work you have already done it won't be a problem for you. Loving the photos. Neil
Mal W
« Reply #41 on: April 17, 2020, 03:58:56 PM » |
Thanks Neil, no not a lot left. Nothing like a challenge. Errol, still got the FB. Haven't even had any genuine enquiries on it either. I've set my bottom dollar at 50k, If I can't get that for it, it can sit in the shed with the others.
Malcolm WHITTAKER
Mal W
« Reply #42 on: April 26, 2020, 01:52:26 PM » |
Malcolm WHITTAKER
« Reply #43 on: April 26, 2020, 05:27:44 PM » |
Brilliant, Mal. It looks like you have a clamp for every conceivable application . . .
« Reply #44 on: April 26, 2020, 09:18:19 PM » |
Lovely job Mal. I hope the trans fits. Cheers Clay
Offline
« Reply #45 on: April 27, 2020, 07:44:46 AM » |
Great stuff mate ,she lives again ..stay well Vern .
camxsmith
« Reply #46 on: April 27, 2020, 08:01:09 AM » |
Mal mate I was just looking at yesterday .. Now you done one could you maybe make another .. Looks really nice well done
« Reply #47 on: April 27, 2020, 08:51:17 AM » |
Nice Mal very nice.
Brett027
« Reply #48 on: April 29, 2020, 12:30:16 PM » |
Amazing metal craft. There is so much talent in this group. Its amazing. Thanks for posting the fabrication sequence.
Mal W
« Reply #49 on: May 14, 2020, 08:37:22 PM » |
Malcolm WHITTAKER
Longman
« Reply #50 on: May 14, 2020, 08:39:54 PM » |
Very nice work mate.
« Reply #51 on: May 14, 2020, 09:35:08 PM » |
. . . I'd say you succeeded in keeping warping to a minimum.
« Reply #52 on: May 14, 2020, 10:53:50 PM » |
Great job Malc. Yes the panel above would have been very susceptible to distortion. I’ve got to do the same repair on my EK van when I get to it. You did well to get a nice solid cut as this is another of the tailor made rust traps that the General kindly endowed us with.
Mal W
« Reply #53 on: June 02, 2020, 08:09:01 PM » |
Malcolm WHITTAKER
« Reply #54 on: June 02, 2020, 10:18:24 PM » |
See you took care to preserve the original rails and outrighutriggers Mal and wondering why, as seems like they will be replaced. I guess you just wanted to use them to keep the quarters braced in position.
Mal W
« Reply #55 on: June 03, 2020, 12:01:10 AM » |
Yep you got it Errol, the original rails are just there to keep everything square and straight until I get the new chassis clip. The new chassis is narrower by 100 mm and will actually fit inside the original rails.
Malcolm WHITTAKER
« Reply #56 on: June 03, 2020, 12:09:24 AM » |
Ok, don’t want to spoil the plot but it’s pretty obvious, seeing you’re straightening the original tubs, that you are going to make it look factory at least above the cargo floor by re-using. I must say I like the idea. While it is desirable to be able to fit big rubber and still get nice and low, I’m not so keen on the sheet metal fabricated wheel tub look in the back of a ute. Great stuff.
Mal W
« Reply #57 on: June 03, 2020, 09:26:42 AM » |
Yes I don't like the look of the fabricated tubs either, I'm going to put about 60 mm in each side and refit them so it has the original appearance. Not that any of the mechanical s will be original but the body will mostly be.
Malcolm WHITTAKER
Patrick_R
Offline
Penrith NSW
« Reply #58 on: June 03, 2020, 10:19:03 AM » |
Lovely work mate.
Looking forward to more pics.
Stewy
sa-club
Offline
« Reply #59 on: June 03, 2020, 04:46:03 PM » |
Great progress Mal. sure is looking good. Cheers Stewy
