« Reply #20 on: March 17, 2020, 10:45:56 AM » |
Hydrochloric acid? - Danger, Will Robinson.
Hydrochloric activates the metal surface and makes it rust before your eyes. Even after you think you've cleaned the last traces of the acid off. And the fumes get in everywhere and promote corrosion.
Phosphoric acid (aka Deoxidine) is a much better product to use. It passivates bare metal surfaces.
Mal W
« Reply #21 on: March 17, 2020, 01:52:06 PM » |
I've used hydrochloric acid a lot on very rusty metals in the past and always after thoroughly cleaning it I treat it with deoxidine and never had a problem.
Mal
Malcolm WHITTAKER
« Reply #22 on: March 17, 2020, 02:08:26 PM » |
OK. Your experience of HCl is better than mine, then . . .
« Reply #23 on: March 17, 2020, 02:47:32 PM » |
Yes the flat tailgate repro skins. Put one on my FB Ute, the inner of which was pretty good. Foolishly I hoped that the skin would form a curve to match the inner. Perhaps if I had put some pie cuts in the upper lip but no. The new skin straightened out the inner of course. Still looks pretty good to the average punter like me. It's only an FB after all.
Billy Blackarrow
Offline
« Reply #24 on: March 17, 2020, 06:27:54 PM » |
It's only an FB after all. EK CLAY Bite your tongue
BILLY BLACKARROW
Mal W
« Reply #25 on: March 17, 2020, 11:08:37 PM » |
Malcolm WHITTAKER
« Reply #26 on: March 18, 2020, 01:58:27 PM » |
All I can say is WOW  Regards Neil
« Reply #27 on: March 18, 2020, 04:39:50 PM » |
You are posting these photos in real time? Because you appear to have done in a day what took me a couple of months . . .
Mal W
« Reply #28 on: March 18, 2020, 09:11:17 PM » |
Rob I've been on this for about 2 months, on my days off.
Just got the forum worked out and now putting up photo's to get up to where I'm at, at the moment.
Only just finished the lower A pillar yesterday.
Mal
Malcolm WHITTAKER
« Reply #29 on: March 18, 2020, 09:40:18 PM » |
Mal,
Just imagine what might happen if you are forced to self-isolate inside the workshop for two, three, or four weeks. As a public health and safety measure, you understand . . .
There are now so few people still at work that I'm hoping the powers that be will shut the doors, and then . . . I can spend a couple of weeks uninterrupted on a project that's been languishing too long in the car port.
Mal W
« Reply #30 on: March 18, 2020, 09:52:32 PM » |
Rob, I'd be pretty happy with that....
Malcolm WHITTAKER
Mal W
« Reply #31 on: March 18, 2020, 10:17:27 PM » |
I was recently looking at all the different new front suspensions that's available and one popped up on the for sale site. So its now in my shed Front end from Rod Shop complete with power steering, lowered stubs, wilwood brakes. Also a full chassis strengthening kit, that I won't be using and a tilt stainless steering column with shaft and unis. Also a large trans tunnel that I also needed. Pretty happy with that. Its all new, never been fitted to a car.
Malcolm WHITTAKER
Offline
« Reply #32 on: March 19, 2020, 07:54:07 AM » |
That is excellent Mal, passion mixed with skill ,keep it up ..Vern ..
Billy Blackarrow
Offline
« Reply #33 on: March 19, 2020, 11:31:01 AM » |
Mal What is the power steering out of and is it modified to suit
BILLY BLACKARROW
Mal W
« Reply #34 on: March 19, 2020, 01:13:45 PM » |
Not sure what the steering rack is originally out of as it is supplied standard with The Rod Shop front ends.
Malcolm WHITTAKER
« Reply #35 on: March 19, 2020, 03:47:33 PM » |
Fantastic work Mal, the photo of the old “A” pillar section shows what was left of the strengthening block that sits between the outer skin and the inner sill. When I did mine, I was lucky enough to have most of the blocks left so I cleaned them up and fitted a cut down a piece of 50x50mm square tube and welded it inside then put a new piece over the top. By the way, your looks a lot neater finished job that mine!!
Gropedawg57
« Reply #36 on: March 21, 2020, 11:09:39 AM » |
Nice work man, love it
Sent from my SM-G960F using Tapatalk
Mal W
« Reply #37 on: April 16, 2020, 06:11:08 PM » |
Next the LH front corner panel Inside wasn’t to bad as at some stage someone had put a new outer end of the floor brace and done a repair to the inner part of the front corner. Just a pity it was all a crap repair.  The outer section was a total mess  Started by cutting all the crappy outer section out   Now to start rebuilding the corner     With that done I went on to fit the new outer floor cross member panel
Malcolm WHITTAKER
Mal W
« Reply #38 on: April 16, 2020, 06:23:53 PM » |
And moving right along I did a bit of cutting and messing around to get the new transmission somewhere close to where it needed to be before starting on the hump section part of the floor cross member that goes over the top of the transmission
Malcolm WHITTAKER
« Reply #39 on: April 16, 2020, 06:56:49 PM » |
Lovely work Malcolm. FB sold?
