August 25, 2025, 02:55:08 AM *
Author Topic: N.O.S. PARTS  (Read 5546 times)
old-blu
« on: February 17, 2020, 01:46:16 PM »
        2  Fibre Timing Gears. [large shaft 7430922]   $ 30. each.
        3  Fibre Timing Gears  [ 7414360 ]                 $ 30.  "
        3  Rear Springs to body Shackle pins.             $  15   "
        Oil pump Gear set.                                     $  20.
        Dip Stick   $5
        Flexidrive   Speedo cable [complete, cable & casing]   $60.
6th, may 1958 "I was there".
old-blu
« Reply #1 on: February 17, 2020, 01:57:57 PM »
       Oil Pressure Switch.  $20.
        Thermostat sender unit [NASCO]. $45.
        "            "         "   [ Rare Spares]. $35.
        Points  EH. $20
        FX_FJ $20.
        FC [engine No. B245605 on]. $ 20.
        TORANA HUB CAP [2825821]. this h/cap is in show cond. [ the flash shows some blemishes, which are invisible to the naked  eye] $50.
old-blu
« Reply #2 on: February 17, 2020, 02:16:39 PM »
       Drag link set [used]. $25
        Tie Rod adjusting tubes & nut [used]. $15
        cowl vent lever [ complete]. $35.
        OIL CAPS. Grey.- Embossed Black. -  Black with Decal.  $20 each.
        Horn Button [good cond, suit d/driver + box. $25.
        Reversing lenses [2] $10 each.
        FE Blinker lenses [2], $30 each.        POSTAGE NOT INCLUDED.
Longman
« Reply #3 on: February 17, 2020, 02:28:56 PM »
I'll take the horn button mate. Will message you.
ipg
« Reply #4 on: February 17, 2020, 02:35:51 PM »
ill take the grey oil cap, oil sender and nasco thermo
« Reply #5 on: February 17, 2020, 08:20:44 PM »
I'll be happy with the dip stick please. I need to check the timing gear shaft size, the last one I bought was RS stock years ago.
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #6 on: February 17, 2020, 09:15:18 PM »
Could I purchase the oil pump gear set please Kevin.
Weddo
Bill Wedd
« Reply #7 on: February 18, 2020, 06:56:19 AM »
Stop press ..Timing gear pls Kevin ..Add to existing parcel if not too late ...Vern ..I'll PM you also..
collecta
« Reply #8 on: February 21, 2020, 01:28:15 AM »
I will grab the 3 spring bolts please...
Scott
Rip
« Reply #9 on: February 21, 2020, 08:54:22 PM »
G'day Kevin
If you have a 7414360 timing gear still available I'll have one please. Will pm you also .
