August 19, 2025, 11:53:56 PM *
Author Topic: FE (vacuum) fuel pump diaphragm replacement kit  (Read 3046 times)
JohnBM
« on: August 14, 2019, 04:51:58 PM »
I’ve noticed in the kit available that the diaphragm is of one thickness(layer) only as opposed to the original AC type which was comprised of multi layers  , any thoughts on this ? I’m having doubts that it will work , or as effectively as the original, made   You know where . Cheers John .
« Reply #1 on: August 14, 2019, 05:48:09 PM »
John,
I've used these single-layer diaphragms without any trouble.  But I would only suggest replacing yours if there's a hole in the diaphragm, or if the link is broken.
JohnBM
« Reply #2 on: August 14, 2019, 06:27:49 PM »
Thanks Rob; I have a second fuel pump as a spare ( you know me ) the trouble with me is I like to know that the spare will work when needed , but your right , I’ll let sleeping dogs lie and carry the kit with me . Wangaratta next run to come , cheers
