fe van
Offline
« on: January 07, 2019, 07:20:14 PM » |
G'day all, Restoring door hinges, has anyone used the rare spares kits? I have found some of my van front door hinges but I'm missing the screws to the A pillars I know originally they were cross heads but I noticed the rare spares ones are a straight slot, just wondering what others have done for these hinges I'm also chasing one more hinge I'll be at the nsw club meeting if anyone can help out thanks.
« Reply #1 on: January 07, 2019, 10:50:34 PM » |
I used Rare's Door Hinge Repair Kits & Door Hinge Spring Kits. Both worked well. I had the original screws for the pillars but was missing some of the shaped star washers. They were a problem to find on their own. The club could be your best bet. For me, the cross head screws are probably easier to tighten. A fastener specialty shop may be able to source them & they would surely have the hex head bolts & spring washers.
Dave 0417 270 315
Offline
« Reply #2 on: January 08, 2019, 06:49:54 AM » |
G'Day FE Van ..I needed some door hinge to pillar screws ,as had to destroy them to get them out ,Rusty ( club member )came to the rescue ,I swapped him ,he may have some more or can tell you where he got them ,they are hardened steel and allen key fit ,was able to salvage the dish star washers ,go in beautifully with impact wrench .Vern .
« Reply #3 on: January 08, 2019, 08:14:49 AM » |
I have plenty of the original Phillips drive door bolts available in good order
fe van
Offline
« Reply #4 on: January 08, 2019, 10:58:07 AM » |
Thanks for the info, I'll let you know Ken if I need some thanks.
Darren
« Reply #5 on: January 08, 2019, 03:12:38 PM » |
The allen key headed bolts sound a bit like the after market HR disc rotor bolts I bought at my local bolt shop . I have used the pin parts of the Rare spares kits ,as when I pulled my van hinges apart I found the pins riding out and totally worn on one side . So I put the new pins in and tacked them so they would stay in .
waynos
Offline
patience grasshopper
« Reply #6 on: January 08, 2019, 05:00:20 PM » |
pretty sure they are 5/16 unf countersunk bolt. most industrial bolt suppliers(or a good bolt shop) should have them. they would most likely be allen key head though. i actually like the look of them better myself. if its a full on resto ,this wont help you .
« Reply #7 on: January 08, 2019, 09:35:20 PM » |
For anybody who needs them, I'll sell a set of 12, no make it 15 with a couple of spares, for $10 plus postage.  Ken
fe van
Offline
« Reply #8 on: January 09, 2019, 09:40:49 PM » |
Hi Ken, I'll take 15 thanks inbox me contact details please thank you.
Darren
waynos
Offline
« Reply #9 on: January 13, 2019, 08:41:43 AM » |
while we are on this subject , where do you get those star washers for the countersunk bolt?
« Reply #10 on: January 13, 2019, 08:47:33 AM » |
I reckon you use a readily available flat star washer which gets pressed in to shape on torque up.
« Reply #11 on: January 13, 2019, 05:38:31 PM » |
I've tried that, they just break  Ken
« Reply #12 on: January 13, 2019, 10:52:12 PM » |
Offline
« Reply #13 on: January 14, 2019, 07:52:46 AM » |
I have asked Ken to put some aside for me ,as the allen drive ones I got from Rusty were to test fit the doors before paint ,but not original , I didn't want to end up with mixed screws..I haven tried to source dished star washers ,some one will enlighten us on this forum no doubt ..Vern
Rabbitoh
Offline
FE - 'King of Cars'
« Reply #14 on: January 14, 2019, 10:52:29 PM » |
Just make sure you heat the washers before you torque them up😏
Fortius Quo Fidelius 1966; Saints' 2nd in 2026? Bunnies' 22nd in 2026?
Offline
« Reply #15 on: January 15, 2019, 06:50:07 AM » |
The ones Ken has include the washers ..I haven't looked for dished star washers for any reason ,probably cant buy them Holden prob did their own thing,,I was thinking getting old screw ,countersunk plate steel ,or old hinge ,put external star washer on screw drop into countersunk hole ,make sure its central, head taper should do that, bit of heat and press it in and form dish shape ,lot less stress on washer ...Vern
waynos
Offline
« Reply #16 on: January 27, 2019, 09:20:28 AM » |
thats what ill be doin i think, unless someone can source them somewhere
« Reply #17 on: January 31, 2019, 08:45:01 AM » |
Those washers, if made from flat washers will lose the twist on the spigots and will not lock so best to lock the bolts in with something .
Offline
« Reply #18 on: January 31, 2019, 08:58:01 AM » |
yes good point ,I have an old Blackwoods catalogue ,that's info only ,then got to find someone who has em ..I don't think I have come across that style anywhere else..good fun in this humidity ..
ehsv6
Offline
« Reply #19 on: January 31, 2019, 03:01:22 PM » |
