August 09, 2025, 03:18:08 AM *
Author Topic: FC Front Brake Backing Plate  (Read 2277 times)
Maco
« on: September 01, 2018, 09:00:10 AM »
Are FC Front Brake Backing Plates the same as FB/EK?
Thanks in advance for any assistance.
Better in Green
« Reply #1 on: September 01, 2018, 09:58:54 AM »
John,
The dimensions of the FB/EK brake backing plate are different from FE/FC, to accommodate the wider shoes and drums.  You can't put FB/EK shoes on FE/FC backing plates - the wider shoes won't engage properly on the anchor pin and the wheel cylinder adjusters.  And then if you try fitting an FB/EK drum to FE/FC brakes, the drum will scrape on the backing plate before it seats on the hub.
Maco
« Reply #2 on: September 02, 2018, 08:43:29 AM »
Thanks Rob,
Better in Green
