August 30, 2025, 03:29:24 PM *
Pages: 1 ... 4 5 [6] 7 8   Go Down
Author Topic: Butchered Fc ute  (Read 59305 times)
« Reply #100 on: April 07, 2019, 08:42:45 PM »
Walk the front clip off?
waynos
patience grasshopper
« Reply #101 on: April 07, 2019, 09:08:29 PM »
yep!
i didnt need to wait till monday  to borrow my mates engine crane...
got it done!
waynos
« Reply #102 on: April 07, 2019, 09:16:35 PM »
Glad I took the subframe off....found all this nasty stuff. How's that rusty subframe bolt???
Sent from my CPH1725 using Tapatalk
« Reply #103 on: April 07, 2019, 11:01:16 PM »
All too common I’m afraid. I’ve used Selleys butyl mastic on those contact areas and make sure no dirt or moisture can get in there when it’s repaired and put back together. Used the small tech screws, extra ones to ensure the apron is sealed tight against the body. Then a coat of paint or two over it all. Better late than never.
waynos
« Reply #104 on: April 14, 2019, 04:18:50 PM »
Got some rust done where subframe bolts on, and decided to delete wiper motor and wiring loom holes. Seems like I've done so much but hardly anything to show for it in the last week. All those little details take time that no-one sees. I'm happy though.
waynos
« Reply #105 on: April 14, 2019, 04:21:40 PM »
I'm happy I can move forward  knowing there's no rust anywhere in the firewall now.
waynos
« Reply #106 on: April 30, 2020, 06:03:38 PM »
The ute has been on vacation for a while in a storage shed whilst other life things happening. It's finally home and time to get into it again. My old booster stuck out and looked stupid so Im trying to recess the booster right inside the firewall.
So happy to be working on it again
« Last Edit: April 30, 2020, 06:09:48 PM by waynos » Logged
waynos
« Reply #107 on: April 30, 2020, 06:08:43 PM »
i am blatantly stealing petes recessed booster idea..credits to you mate!
« Reply #108 on: April 30, 2020, 08:49:48 PM »
Good to see you are back at it wayno. I was surprised to see your last post was a year ago.
camxsmith
« Reply #109 on: April 30, 2020, 09:26:10 PM »
Really nice work
waynos
« Reply #110 on: May 01, 2020, 07:03:08 PM »
i bought this car as a rust free (supposedly) car maybe 12 years ago .car is rust free still in common areas where they usually rust.
so was just surprised to find that rusted bolt so far gone when the whole car is virtually rust free still,the rust repairs youve seen are the only bad bits in the car.
im about to chop the right hand quarter panel off just to be sure
my8thholden
« Reply #111 on: May 02, 2020, 07:58:04 AM »
Hand cut ,wow , I was thinking nibbler or laser cut ,well done ..Vern
waynos
« Reply #112 on: May 06, 2020, 08:11:25 PM »
So finally back into it with the recessed booster idea.  Not sure how far I can get it in the firewall. But it will build itself. Here is today's effort.
[IMG]https://uploads.tapatalk-cdn.com/20200506/369b0dbc0faa1b8f0f6c
« Last Edit: May 06, 2020, 08:24:59 PM by waynos » Logged
waynos
« Reply #113 on: May 06, 2020, 08:29:04 PM »
Let's see if I can get it recessed this far
« Last Edit: May 06, 2020, 08:36:36 PM by waynos » Logged
« Reply #114 on: May 06, 2020, 08:38:39 PM »
That red label will give you the muscles you need for the job wayno
waynos
« Reply #115 on: May 11, 2020, 04:45:15 PM »
Some more booster stuff.
« Reply #116 on: May 11, 2020, 08:08:59 PM »
Nice work. You might look at reversing the steering shaft upper joint as well to reduce any binding.
FireKraka
« Reply #117 on: May 12, 2020, 09:13:08 AM »
Hey Wayno nice metal work there mate to get the recess.
Can I ask if you recess so far does it effect the travel of your brake pedal, just wondering how much you have to mod inside.
Neil
waynos
« Reply #118 on: May 12, 2020, 06:24:34 PM »
no it wont help .they are the same both ways
i drove this car before .there was no binding .it worked well.
previous owner ground the knuckles to stop it binding.
i fixed that problem years ago.
probably just looks crap on the angle of the photo
waynos
« Reply #119 on: May 12, 2020, 06:28:40 PM »
Neil
its recessed about 85 mm
just misses handbrake and  gives enough travel for the pedal
it was all guesstimated ,  i got seriously lucky aswell
Pages: 1 ... 4 5 [6] 7 8   Go Up
Page created in 0.047 seconds with 16 queries.
