August 08, 2025, 06:56:39 PM *
Author Topic: HELP ! h4 headlight bulb replacement  (Read 4446 times)
surferboy
10,000 POINTS !
« on: June 24, 2018, 02:57:52 PM »
knowing the wagon has modifications that has mechanics scratching thier heads...
How hard could it be to change a light bulb ? i thought to myself
pulled out the headlight ( thats a story of it's own!) and thought i just unplug the wires, unclip the bulb, pull it out then do reverse to fix it.
This white bit does NOT want to budge
Do i just need to be more forcefull or gently persistent  ?
or am i pulling apart the wrong bit ! ! ! ?
surferboy
(the clueless)
Sent from my GT-I9505 using Tapatalk
cruisin's great with a 58
« Reply #1 on: June 24, 2018, 03:06:15 PM »
Just a bit more forceful. Wiggle left, wiggle right, wiggle front, wiggle back. Pull! Repeat.
When you get the bulb out, do not touch the new bulb on the glass area. Handle it only by the steel end of the bulb. Any grease off your fingers will make the new H4 bulb burn out really quickly. If you accidently put your fingers on the glass, clean it thoroughly with metho.
fastjbav6
OK start her up !
« Reply #2 on: June 24, 2018, 03:26:28 PM »
Hey Surferboy,
Remove rubber dust cover at back of head light.
Release the tension of the spring loaded clip that holds the light bulb in.
Globe should fall out.
Regards Seb
Yellow Knight
surferboy
10,000 POINTS !
« Reply #3 on: June 24, 2018, 11:22:49 PM »
WHOOPS.   I forgot something
this is why i pay other people to do things
surferboy
10,000 POINTS !
« Reply #4 on: June 24, 2018, 11:32:23 PM »
I have one old slotted screw & 2 new allenkey screws holding the light onto the body.  I think these should be adjusting screws but they screw tight to the bodywork (no springs). if i don't screw them all the way in the chrome surround doesn't sit on properly
« Reply #5 on: June 24, 2018, 11:42:26 PM »
Surferboy
Some of us will be wondering whether your headlights were originally Bosch units. These have no springs, one static screw that goes all the way to bottom, and adjusting screws at 90deg to each other. A photo of the bucket sans lens would be helpful.
Clay
« Reply #6 on: June 25, 2018, 06:14:15 AM »
To change the bulb:
a) Put the chrome ring back onto the car. Don't need to touch anything outside the engine bay to change the bulb.
b) white plug off first. Wiggle/jiggle then pull. Dont pull by the wires - pull by the white plug.
c) remove rubber dust boot, unhook spring clip and old bulb nearly falls out.
d) new bulb in, don't touch the glass bit.
e) refit spring clip, refit rubber boot.
f) refit white plug.
g) Voila! New lights.
surferboy
10,000 POINTS !
« Reply #7 on: June 26, 2018, 10:22:29 PM »
bucket sans lens
surferboy
10,000 POINTS !
« Reply #8 on: June 26, 2018, 10:46:54 PM »
I got it back together and it works  Grin
(after pulling it apart again to put the dust boot rubbery bit back on )
Not exactly aligned properly but it's good enough for me
(I am NOT pulling that chrome bit off again... it takes me forever to line up two screws to put it back on)
 ( I have little patience  Roll Eyes)
I thought I might be able to access the light from under the front guard and simply just unplug the globe
but the bowl shaped thing was in the way
so
I followed instructions on page 300 of workshop manual
but it doesn't look like the one in the manual  (NOTHING in my wagon looks like anything in the manual  Huh Roll Eyes Shocked Cry)
mine has a lot fewer bits than the one in the manual
the headlight also has two holes in it ( a smaller one below the pluggy in thingy bit)
 Cool Cool Cool
« Reply #9 on: June 26, 2018, 11:02:58 PM »
Thanks for the photo, which confirms you have the Bosch headlight buckets. The second hole I believe identifys the lens as earlier model figment, incorporating parking light. FX FJ I believe. I reckon you need to close that hole somehow to keep moisture out. Maybe a suitable parker globe would do it.
« Reply #10 on: June 27, 2018, 05:13:17 PM »
The FE had the park light in the headlamp bucket. This would be where it is from.
