September 08, 2025, 06:03:37 PM *
Author Topic: Ute rear shocker covers  (Read 2406 times)
Norm
« on: January 19, 2018, 03:07:33 AM »
Can anyone help me?
 I after the size of the two plates that are use to cover the access holes for the rear shockers upper mounts on a FC ute.
« Reply #1 on: January 20, 2018, 08:39:48 AM »
If they are [fairly sure] the same as the van then you are looking at square plates around 10# 112mm [4 1/2"] radiused corners close to the size of a 5cent piece with a 1/8" drilled centre and CSK screws if that helps .
Norm
« Reply #2 on: January 20, 2018, 09:45:28 AM »
Thanks for the help!
I thought they were around that size, but I wanted to them to be correct!
Thanks again!
