August 09, 2025, 02:39:59 PM *
Author Topic: Seeking advice on Gearbox parts  (Read 2196 times)
DJ
« on: November 28, 2017, 11:37:31 PM »
I have a couple of incomplete Wibroc overhaul kits.
From the components listed in the Crash Gearbox Enthusiasts Guide I have a couple of questions:
Q1. Where am I likely to find - Synchro cone retaining rings (two off) & Counter shaft and reverse gear thrust washers (two off)?,
Q2. Is the RS Seal Oil Gear Box Selector 48 FJ FE FC FB EK Part# 7403035 the replacement for Selector shaft seal (NAK Australia part number E062.100.25)?
0417 270 315
« Reply #1 on: November 29, 2017, 07:17:25 AM »
The snap ring is generally only obtained by raiding a wrecked gearbox. I may have one if you are stuck, but am on the road for work for the next fortnight.
Yes, same item.
DJ
« Reply #2 on: November 29, 2017, 10:14:23 AM »
Thanks Harv.
The gear box is still in the car, so assuming the snap ring is intact it seems I should be able to reuse it.
With the Rare Spares seal I think I've made up a full kit.
0417 270 315
