July 18, 2025, 11:01:41 AM *
Author Topic: Engine bay brake line  (Read 4149 times)
walks
« on: November 10, 2017, 07:51:44 PM »
G'day all,
I after photos of the routing of the steel brake line in the engine bay. The one that goes from the 4 way connector to the Lh flexible line.
Walks.
WALKS
« Reply #1 on: November 10, 2017, 09:47:53 PM »
As far as I can remember - up the subframe leg and all the way around the subframe, just under the flange: driver's side, then the front tie member, then the passenger's side to the brake hose bracket.  I think there are even supposed to be spring clips holding the brake pipe to the front subframe tie member under the radiator.
« Reply #2 on: November 11, 2017, 06:28:41 AM »
There are at least 2 tabs punched from the subframe tie member which bend over the line to hold it in place
« Reply #3 on: November 11, 2017, 11:22:03 AM »
This is it. Right round the subframe.
Maco
« Reply #4 on: November 11, 2017, 02:52:29 PM »
Hi Ken,
Is that brake line for sale?
Better in Green
« Reply #5 on: November 12, 2017, 12:04:46 PM »
Yes it is John, but would be very difficult to post to NSW.
What are your thoughts?
Maco
« Reply #6 on: November 12, 2017, 08:08:37 PM »
Hi Ken,
Maybe someone can take the Nationals for me.
Better in Green
« Reply #7 on: November 12, 2017, 08:42:25 PM »
I can do that for you
