July 17, 2025, 04:33:51 AM *
Author Topic: Which column, FC rack & pinion?  (Read 6319 times)
Fast_Eddie
« on: August 15, 2003, 06:56:52 AM »
I'm currently undertaking a V8 conversion into a FC sedan.
I have a CRS HR front end with front mounted rack.
For RTA requirements, I have to fit a collapsable column.
Can anyone suggest a suitable column that will enable me to meet the objectives of keeping an original look, ie dash ignition and FC wheel, column auto shift, and is also collapsable?
« Reply #1 on: August 15, 2003, 09:57:49 AM »
How about an LC Torana column auto? LCs had ignition on the dash so it would be a fairly plain column. AFAIK the LC column is collapsible.
robbzfc58
Gone but not forgotten.
« Reply #2 on: August 15, 2003, 12:04:12 PM »
hk-t-g is also collapsable
robbzfc58
Dr_Terry
« Reply #3 on: August 15, 2003, 06:57:49 PM »
Hi Guys.
The HK/T/G Column is similar to the LC Torana 6 column. However the LC has a better auto trans indicator, which is away from the dash facia.
It's the combination of tha original steering wheel & the column auto selector that is the most difficult.
If you go to a later model steering wheel or a floor selector (or both) your available choice will be wider.
Regards.
Dr Terry.
ekmad
« Reply #4 on: August 16, 2003, 09:32:15 AM »
There is a guy in Beaudesert who can convert EK auto holden steering columns to a collapsible rack and pinion system by using  VB/C/H column parts.  From inside the car you can't any difference and he  rigs up the auto selector to do it's job.  I am not sure whether he can rig up a manual column change.
« Reply #5 on: August 16, 2003, 09:39:19 AM »
ekmad, I for one would like his contact details please, Beaudesert, thats where I got my Ambulance from!
Gary
Fast_Eddie
« Reply #6 on: August 16, 2003, 07:55:23 PM »
Ekmad,
That sounds promising.
Do you have the guy's details.
Where is Beaudesert?
Chuck
Finished!
« Reply #7 on: August 17, 2003, 01:16:45 AM »
Fast Eddie
I would contact this guy: Rod at rodsracks@hypermax.net.au (07) 5541 4967 0419 760 987.  He makes a collapsible column utilising a commodore lower column section mated to your original upper.  That way you can retain your factory wheel, blinkers etc...
If you call him, he will e-mail you an excellent document including pictures - really, really helpfull bloke
Cheers - Chuck
ekmad
« Reply #8 on: August 17, 2003, 06:49:20 AM »
Fast Eddie  -
Chuck has already given you the details of the same guy,  Rodsracks at beaudesert.
EKMAD
Fast_Eddie
« Reply #9 on: August 17, 2003, 08:21:05 AM »
Thanks guys, I'll follow through on it, and let you know the result.
Fast_Eddie
« Reply #10 on: August 19, 2003, 06:06:55 AM »
Got the information from Rod.
Basically he makes a collapsable column out of your early Holden column, the floor plate and a early model Commodore column.
Anyone got a spare column, floor plate and early Commodore column they want to sell? I'll post on parts wanted.
Page created in 0.041 seconds with 21 queries.
