July 18, 2025, 01:59:38 AM *
Author Topic: FE Tow Bar Tongue  (Read 2185 times)
Ken's 57
« on: July 15, 2017, 12:33:36 PM »
Just wondering if anyone has the correct tow bar tongue for an FE sedan please. Or perhaps where I can acquire a new one at reasonable cost. I have an original tow bar fitted but only the main piece that bolts on under the body and which has two 9/16" UNC threaded holes with a distance between the centres measuring 3⅜" (86mm). The tongue, which has always been missing, would require two 9/16" clearance holes the same distance apart and when fitted, not overly obscure the number plate.
Cheers for any assistance or advice,
Ken  Smiley
Maco
« Reply #1 on: July 15, 2017, 07:23:04 PM »
Hi Ken,
An engineering workshop should be able to manufacture one for you from 20 mm X 75 mm Flat bar.
Better in Green
Ken's 57
« Reply #2 on: July 17, 2017, 06:32:07 PM »
Thanks John. Thought that might be the case.
Cheers, Ken
