July 19, 2025, 01:47:55 AM *
Author Topic: Clutch slave cylinder  (Read 2536 times)
BigAlFC
« on: June 22, 2017, 10:37:50 PM »
I have a Aussie 4 speed on my FC with the clutch slave cylinder my problem is that the shaft that comes out of the slave has to be on an angle to fit in the hole on the gear box fork arm is this normal
« Reply #1 on: June 23, 2017, 08:26:46 AM »
Should be parallel to slave cylinder bore. Been a long time but vaguely recall drilling a fresh hole on the lever maybe. I had a cast iron adapter bracket which snapped and  I replaced with a cast aluminium Hadfield one. It kept the slave fairly close to the bell housing. A picture would help.
BigAlFC
« Reply #2 on: June 23, 2017, 11:16:09 AM »
I will send a photo as soon as I work out how
