August 15, 2025, 06:03:42 AM *
Author Topic: Vacuum house for wiper  (Read 2340 times)
clockedin
« on: February 27, 2017, 10:00:10 AM »
Hi all... I need to know where the vacuum house for the wiper goes... Might seem like a dumb question .. I've looked through manual and I can't seem to find where it goes....any help would be appreciated.
« Reply #1 on: February 27, 2017, 10:38:28 AM »
No question too dumb . . .
There should be a steel pipe which runs from the vac. section of the fuel pump, along the bottom of pushrod cover, past the distributor, and then upwards at the rear of the pushrod cover.  The pipe ends at about the height of the cylinder head.  The hose attaches onto the pipe.  The other end of the hose is a push-fit onto the wiper motor.
You just have to avoid the wiring, the choke and speedo cables, and the firewall when routing the hose.
clockedin
« Reply #2 on: February 27, 2017, 07:34:24 PM »
Thanks ardo else... Spot on.... Without you guys I would be in a pickle... Thanks mate.
Page created in 0.029 seconds with 16 queries.
