September 09, 2025, 01:16:59 PM *
Author Topic: Radiators  (Read 6796 times)
DJ
« on: December 15, 2016, 12:35:51 PM »
I made some enquiries about a radiator on Gumtree from a SA radiator business.
The part number looks to be an FJ model. The owner has replaced the core with new 1" tubes.
I had been looking at having my unit redone by Natrad locally, at greater cost.
Any thoughts or advice would be greatly appreciated.
http://www.gumtree.com.au/s-ad/mount-barker/other-parts-accessories/holden-radiator/1132510921
0417 270 315
pbh0069
sa-club
« Reply #1 on: December 15, 2016, 01:29:56 PM »
I had my radiator pulled apart cleaned and 3 small holes repaired by HOLDEN HILL RADIATORS about September ,
the unit was 70 % blocked . Very happy with the service and price .
cheers Phil.
« Reply #2 on: December 15, 2016, 04:41:57 PM »
Mine was around 550 new core fully recod.
« Reply #3 on: December 15, 2016, 04:48:17 PM »
I'll second what Phil says.  If you still have your original radiator core, find a radiator shop which can pull the tanks off and clean the tubes out.  The tubes in replacement cores are much smaller than in the original cores, so run a much greater risk of blockages from small pieces of scale.
But a word of warning: FX-FJ radiators are about 2" taller than FE-EK radiators, even though the top and bottom tanks are interchangeable.
FX radiators have six mounting holes.  FJ radiators have four, but are designed for rubber insulators, so the mounting tabs were moved rearwards about an inch.
FE-EK radiators have four mounting holes.
Hope this helps, rather than confuses.
DJ
« Reply #4 on: December 15, 2016, 05:41:04 PM »
Thanks for the tips everyone.
Looks like the best option is to shop around more & reco the one I have.
0417 270 315
pbh0069
sa-club
« Reply #5 on: December 15, 2016, 07:41:13 PM »
i should have mentioned that mine cost under $200.
i have no affiliation with this shop it was recommended by someone at work who had there mustang radiator done there
cheers Phil.
DJ
« Reply #6 on: December 15, 2016, 08:00:39 PM »
It's good to hear about businesses providing good service & great value.
0417 270 315
« Reply #7 on: December 15, 2016, 08:04:32 PM »
In the photo on gumtree, what are the two fittings on each side of the top tank?
DJ
« Reply #8 on: December 15, 2016, 08:14:45 PM »
He said he had provided for cabling, so I assume that's what they are.
It was an order that wasn't collected.
0417 270 315
Rabbitoh
FE - 'King of Cars'
« Reply #9 on: March 03, 2018, 03:00:50 PM »
Hi,
Need to get a pressure test done on my spare radiator.
Can anyone recommend a good workshop in the inner or south eastern suburbs of Melbourne, who would be able to do the job, and a ‘leak repair’, should it be found to be necessary?
Thanks,
Bunnies' 22nd in 2026?
