May 19, 2025, 03:36:57 PM *
Author Topic: High beams on the light switch.  (Read 3498 times)
« on: September 07, 2016, 04:05:44 PM »
Had the light switch setup so first pull was Parkers AND headlights. Second pull was high beam- which worked until I realised that the rear red night lights were not working when on high beam.
Anyone know how to get around having a dipper switch?
This may void the dipper switch I was looking for in the parts wanted bit
« Reply #1 on: September 07, 2016, 05:17:45 PM »
I'm sure I could find you a dipper switch if you are stuck . You want the original that comes from the underside through the floor ? Your dash lights would also go off on high beam along with your tail lights wouldn't they ? Anyway PM me if you want it back to normal and can't get the bits you need . Cheers Haydn
« Reply #2 on: September 07, 2016, 07:26:47 PM »
Have another look at how you've wired it up. The original switch should have the rear parkers active on both the first and second positions. It sounds to me like the rear lights are on the wrong post.
« Reply #3 on: September 07, 2016, 07:46:51 PM »
Yep, rear lights should work on first and second pull.
« Reply #4 on: September 07, 2016, 10:14:17 PM »
ahh yep of course, didn't even think of that Shocked No requirement for dipper switch now.
