August 21, 2025, 03:40:33 AM *
Author Topic: REMOVING SPRINGS  (Read 5022 times)
Not Happy Jan
Aussie adventure
« on: July 19, 2016, 03:33:55 PM »
Hi All
What is the best way to remove your front springs if the front end is out of the car?
TIA
Nick
You can never have too many!
Port Macquarie NSW
« Reply #1 on: July 19, 2016, 04:14:41 PM »
If you haven't got spring compressors you can loop some strong rope or cord around the upper and lower arms the remove the shocks and the upper king pin pivot and then slowly undo the rope. This should stop the spring from rapid recoil.
« Reply #2 on: July 19, 2016, 04:46:22 PM »
If your wooden fence is good and strong you can use a long board as a lever to compress the spring whilst a mate undoes the upper king pin bolt.
Then slowly release the tension.
JOX515
« Reply #3 on: July 19, 2016, 05:36:03 PM »
very carefully.......
snuff69
« Reply #4 on: July 19, 2016, 06:25:45 PM »
I made my own spring compressor tool Nick.  I got a piece of threaded rod, proper fine threaded stuff from an engineering shop, not crap from the hardware shop. A few big washers and 4 nuts. Worked fine on 2 front ends before I stuffed the threads and had to make another for my next one.   Dave
« Reply #5 on: July 19, 2016, 06:50:15 PM »
LC LJ torana  are much more difficult . You have to weld a piece of tube on the end of your threaded rod to go at the top of the tower. Haydn
« Reply #6 on: July 19, 2016, 08:01:03 PM »
you know what i put mine in with ?
A irwin quick clamp pulled them in beutiful and got them out beutiful
https://www.google.com.au/search?q=irwin+quick+clamp&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj6kfiPov_NAhUHFpQKHVHnDx0Q_AUICSgC&biw=1600&bih=791#imgrc=teBHQ3LMZ2nmBM%3A blue and grey one
Not Happy Jan
Aussie adventure
« Reply #7 on: July 19, 2016, 09:34:21 PM »
I think you told me that before Dave. But the shockies are still in... Will look at that??
Pete. That's a great idea.
Thanks everyone. Funny and useful Grin
Port Macquarie NSW
« Reply #8 on: July 20, 2016, 06:05:36 AM »
SO if you end up with a spring in your forehead you did it the wrong way  Grin
sing out i could get a set out of Marcs old front end and chop and powder coat and send up to you.
