May 20, 2025, 10:56:56 PM *
Author Topic: Bosch Grey motor distributor and FE front Indicator lens/ chrome ring  (Read 3016 times)
ziggy
Terrific Tilleys
« on: June 13, 2016, 11:59:27 AM »
Need either a really good or recoed Bosch distributor for my car in the USA as the hold down spring has broken and seems like no one can fix it (plus its got about 100Kmiles on it). Car is still running but no vac advance and does not start at times.  Let me know I can pick it up from Sydney area to Port Macq end of July. Or does anyone know a Sydney shop that can rebuild one? In that case I wold need a donor.
Also need a FE front indicator lens AND chrome surround (thats what actually fell off)
« Reply #1 on: June 13, 2016, 12:51:30 PM »
Vintage Racing Developments does grey dizzy rebuilds out of Sydney:
http://www.ebay.com.au/itm/Original-EJ-Holden-Grey-Motor-BOSCH-Distributor-Overhauled-Restored-/222148044216?hash=item33b90e25b8:g:Ha8AAOSwyjBW75QC
Hume Performance (Warwick Farm) does grey motor dizzy regraphing - they may also be able to rebuild for you:
https://www.hume.com.au/index.php?option=com_virtuemart&page=shop.browse&category_id=115&Itemid=177
DCE80
sa-club
« Reply #2 on: June 13, 2016, 04:14:24 PM »
I have just bought a dizzy from David  (0410596365) at vintage racing developments. He produces high quality work. Has his own test rig. I haven't mine installed yet but will do soon once I get car off jack stands. He does better price if you ring direct. Doesn't require changeover unit. Very easy to deal with also.
Dan
« Reply #3 on: June 13, 2016, 07:12:24 PM »
Are you sure you need a grey distributor?
Red distributors have a hold down Spring with a single bolt through it
Grey distributors have a hold down plate with a bolt through it so that it would be better described as a locking ring.
ziggy
Terrific Tilleys
« Reply #4 on: June 14, 2016, 12:03:06 PM »
Thanks guys. I will try vintage. ken - it is the plate that is broken. Definitely a grey. Someone here tried to rebuild it but likely did more damage. Need a new one anyway.
