August 30, 2025, 06:36:52 AM *
Author Topic: Raising rear ride height  (Read 6578 times)
njf690
heya
« on: June 03, 2016, 05:47:03 PM »
Guys after advice on lifting the rear ride height on the FC sedan . She is scrubbing on the new rims . I will roll the inner guards but still think the ride height has to come up . Also shocks of any one can recommend some I'm in Brisbane . Don't know how to post pictures
« Reply #1 on: June 03, 2016, 07:24:21 PM »
you can fit a LJ diff to get them tucked under.
I only use monroe GTs..
Is this the facebook one with 15 inch smoothies ?
« Reply #2 on: June 03, 2016, 07:27:20 PM »
A couple of extra leaves eg ute or van springs will give you one or two inches. Monroe gas from super sprint barn will do for dampers.
« Reply #3 on: June 03, 2016, 09:26:54 PM »
Wagon springs have 1 more leaf and will stiffen up and lift the rear a little. Ute or van springs have 2 more leaves and will double the lift.
i like Monroe shockers as well but don't use a pump up shocker as these will crack the mounts on the rear floor
njf690
heya
« Reply #4 on: June 03, 2016, 09:51:25 PM »
Yeah the missus put it up on Facebook
« Reply #5 on: June 04, 2016, 06:52:45 AM »
when you say roll the rear guards i remeber doing this when i was 15 on my sedan and they are extremely hard as its a multi layer panel ends up cracking the radius on the edge and still doesnt achieve much as the inner guard steps in pretty quick as well was a lesson learnt.
What size tyre are they ? i just fitted 15x7 alloy wheels to my wagon cannot remeber the offset and with 205 50 15  and they rubbed ever so slightly and mine is pretty low .
Have a quick look at my wagon page Petes fc wagon
If you want to go up on the springs mark which is left and right pull them out and take to a spring mob . I just had a set lowered for $280 from memory but im sure going up is the same.
njf690
heya
« Reply #6 on: June 04, 2016, 07:21:55 AM »
They are 15/6 rims right round . They springs have been reset .
VAN059
Brisbane, QLD.
« Reply #7 on: June 04, 2016, 07:38:21 AM »
If you're south, try talking to Bayside Springs & Blacksmithing. They can reset for lowering & reset/add for raising.
They've reset my rear springs on a few of my earlies over the years, and I've never had an issue.
njf690
heya
« Reply #8 on: June 04, 2016, 07:50:58 AM »
Yeah that who did them . I will give them a call and see what he can do
Page created in 0.032 seconds with 17 queries.
