May 22, 2025, 12:10:17 PM *
Author Topic: Holden 186 camshaft identification  (Read 6431 times)
camxsmith
« on: May 28, 2016, 05:48:49 PM »
Hi
   Hoping some one can help identify the two camshafts I have, both came out of 186 engines.
1.  First one has STL 1635 (the 6 could be something else), with a big 8  stamped on the end. and no other stamps of marks on the shaft.
2. Second has 0 and 6 (or 9) stamped on the end. It once had I believe Holden stamped into the shaft and a number starting with 1.
« Reply #1 on: May 29, 2016, 10:23:18 AM »
I have one with XU1 stamped on it .
« Reply #2 on: May 29, 2016, 10:07:46 PM »
The second one is a 202 cam  what the ident is i unknown ...the first may be a Waggot cam or Author Johnson  and that would make the number a Master number
camxsmith
« Reply #3 on: May 30, 2016, 07:52:49 AM »
Thanks I will see if I find out more from your info ...
« Reply #4 on: May 30, 2016, 02:10:53 PM »
The first one could be a worked cam, the numbers could be the grind. May be ring or take it to a cam specialist, they would be able to set you straight.
camxsmith
« Reply #5 on: May 30, 2016, 02:27:51 PM »
I was thinking about doing that Jim..  Thanks for you reply
Closure inspection you can see a small fish shape stamped under the number   6   ..  Does any one know about the fish stamp
