August 19, 2025, 01:51:29 PM *
Author Topic: Oil Filter adapter  (Read 7702 times)
ACT59FC
« on: March 16, 2016, 09:16:14 PM »
I recently purchased an AC oil filter, I am after an adapter to screw into the block. The one you screw the oil sender into as well as the braided line that goes to the filter. If anyone has one they are willing to sell I'd love to hear from you.
Regards Rod.
FC the Marilyn Monroe of Holdens. All the curves in exactly the right places!
« Reply #1 on: March 17, 2016, 06:23:32 AM »
Your local hydraulic shop or some parts places have lots of brass adaptors and fittings that should get you out of trouble.
Fraze
« Reply #2 on: March 17, 2016, 07:40:23 AM »
I got all the bits I needed from my local Pirtek shop, Fraze
ACT59FC
« Reply #3 on: March 17, 2016, 07:42:13 PM »
Thanks gents Ill try the hydraulics places here in Canberra. Doles the inside dia of the brass fitting have to be any particular size for oil pressure setting?
Rod.
« Reply #4 on: March 18, 2016, 06:44:03 AM »
Rod.
Oil pressure and grey motors dont mix Rod... Cheesy
Whatever you use im sure it will be enough.
« Reply #5 on: March 18, 2016, 06:51:35 AM »
Petes's right... greys do not like a full-bore flow on a remote filter. You will starve the block. The system needs a restrictor of about 1.5mm diameter in it. More info here:
http://www.scribd.com/fullscreen/56830215?access_key=key-1e6pc13gvi0gfjj7wqjv
gp
« Reply #6 on: March 18, 2016, 06:53:42 AM »
Hi Rod,
One of our club members works for Pirtek.
Give Matt Withers a call on 0414584524
ACT59FC
« Reply #7 on: March 18, 2016, 10:41:01 PM »
Thanks Pete, Harv and Graham for the advice. Ill contact our Pirtek contact next week. Thanks Harv for the link to the FB/EK document. Nice to know modern cars used the same filter  Grin
Rod.
« Reply #8 on: March 19, 2016, 10:37:45 AM »
Yes tried a full flow system on a grey once .[Valiant remote filter on the inner guard] Seized engine . Pulled the dipstick because the oil light came on just before it squealed to a stop and guess what ? No oil showing on the stick . Gave it 3 minutes and the sump was overfull . Lesson learned . If anyone is interested I have one of these AC Delco setups in my spares [hoses,restrictor, canister and bracket and clamp it came of an early Hillman Minx ] .Haydn
ACT59FC
« Reply #9 on: March 19, 2016, 09:49:54 PM »
Do you use a remote filter Haydn? Or do you prefer to just leave it and change the oil more regularly? I like the thought of at least some filtration of the oil.
Rod.
« Reply #10 on: March 20, 2016, 11:07:52 AM »
Most of us today use our old Holdens  sparingly and around here I am probably the last guy to use an FC as a daily drive [work horse ] . I always felt better after giving the old girl a full service . Either way , oils are much better than they were and roads less dusty . I know , that didn't answer your question ,but yes I've run plenty with and without . In balance I don't know if there is much difference .Extra oil changes verses filters . Air filter and breather cap are also important . This might be of interest to someone . I watched Dr Blake the other night and he was experimenting with nepheline and I remembered that the old bloke I got my FC van from told me he would put moth balls  in the fuel tank as well as those blue bleach bombs[ copper sulphate ] in a piece of stocking in the top radiator hose . Just thought I would put it out there to see what people think. Cheers Haydn
pbh0069
sa-club
« Reply #11 on: March 20, 2016, 04:51:30 PM »
picked this up at swap meet today , this insert was in the paperwork .
cheers Phil.
ACT59FC
« Reply #12 on: March 20, 2016, 05:36:44 PM »
Thanks Haydn and Phil, Much appreciated. Good pickup Phil. Looks like its in great condition.
Rod.
pbh0069
sa-club
« Reply #13 on: March 20, 2016, 05:42:03 PM »
it looks NOS , seller did not know anything about it.
cheers Phil.
