August 20, 2025, 11:33:51 PM *
Author Topic: Boiling temp of water with 7lb radiator cap.  (Read 3237 times)
graham_fuller
« on: February 13, 2016, 10:39:50 PM »
Hi all,
The question is as above. I was stuck in a major traffic jam today in 35 degree heat water temp gauge was reading around 80 degrease or a little more, the temp light didn't come on. So should I assume it didn't boil?
Graham
graham_fuller
« Reply #1 on: February 14, 2016, 06:26:53 AM »
What I should have said was the boiling point of coolant at 7lbs pressure?
Graham
« Reply #2 on: February 14, 2016, 07:26:33 AM »
Graham,
Probably didn't boil. Check water level anyway to be certain.
atmospheric pressure water boils at 100ºC at sea level.
a 7psi cap boils at about 110ºC.
a 9psi cap boils at about 113ºC.
a 12psi cap boils at about 118ºC.
Adding coolant chemicals like glycol can change this a little, as can operating at other than sea level.
« Reply #3 on: February 14, 2016, 01:02:19 PM »
Got me curious... even at the top of Mount Kosciuszko, a 7psi cap would still boil at about 105ºC.
Geoff_K
The 2 BAY s
« Reply #4 on: February 17, 2016, 04:02:13 PM »
Graham,
If you are stationary, the outside temp is 35º, and your temp guage is holding 80º, you have a damned good cooling system.
Most standard motors/radiators, under these circumstances (assuming at idle/no load) would over time tend to creep up to 100/105º, and only if you are loosing water (leaks in water pump, cap, cracked head, cores, hoses etc) will temp run up enough to flick on the temp light and give you grief.
If you are towing a van, or climbing a mountain, things could be worse!
Cheers Geoff_K
Page created in 0.024 seconds with 17 queries.
