July 18, 2025, 04:14:01 AM *
Author Topic: FREE - 5 speed gearbox conversion  (Read 6258 times)
Longman
« on: February 11, 2016, 12:02:32 PM »
Hi. Just removed from an FC sedan. Complete conversion as follows:
- Sigma 5 speed gearbox with shifter
- Adapter plate for red motor
- Clutch and pressure plate
- Starter motor
- Slave cylinder
- Tailshaft with Banjo fitting
- Custom crossmember.
Gears select smoothly. I have not driven this box, so is a giveaway AS IS. Pickup Mount Hutton , Newcastle. No floor tunnel mods were made on my car to fit this other than hole for the shifter. Conversion was done in the 80's by Rod Hadfield. PM if interested. Need it gone ASAP.
« Last Edit: February 11, 2016, 12:07:34 PM by Longman » Logged
« Reply #1 on: February 11, 2016, 10:05:40 PM »
Ill take it for my wagon as i do not want to cut the floor if its still available.
But would like to give u cash or grog
Crumpsnr
Shellharbour NSW
« Reply #2 on: February 11, 2016, 10:13:41 PM »
Might be a bit long and interfere with the bench Pete. I had one in a sedan years ago and I had to go to to buckets. Regards,
Martyn
Longman
« Reply #3 on: February 12, 2016, 06:48:56 AM »
PM sent Pete.
« Reply #4 on: February 12, 2016, 12:21:52 PM »
Martyn
Thanks martyn ill check it out.
Im currently doing commodore 6sp shifter relocation set ups for a fella so may be able to move the shifter on this one
Page created in 0.042 seconds with 18 queries.
