September 09, 2025, 06:24:31 AM *
Author Topic: Aussie 4 speed help  (Read 5504 times)
« on: January 31, 2016, 11:18:00 PM »
We have a few Aussie 4 speeds about, but I found one in our collection that has a sender installed just under the 3/4 shift lever.
It looks like a factory fit-up, can anyone shed some light?
« Reply #1 on: February 01, 2016, 07:43:17 AM »
Reverse lights ?
« Reply #2 on: February 01, 2016, 08:03:55 AM »
http://holdenpaedia.oldholden.com/Aussie_Four_Speed
« Reply #3 on: February 01, 2016, 09:57:32 AM »
Thanks Pete, I found the answer in that link -
The Transmission Control Switch only permits Vacuum Advance in Top Gear when the Engine Temperature is above 63 degrees C.
Dr_Terry
« Reply #4 on: March 09, 2016, 01:13:20 PM »
That is not quite correct. The switch on the gearbox side-plate simply tells the emission system that the gearbox is in fact in top gear (4th in a 4-sp or 3rd in a 3-sp). The 63 degree switching is operated by a separate temp which is mounted in the cylinder head directly into one of the many mounting, detecting the the temp. of the actual metal.
Dr Terry
Page created in 0.028 seconds with 19 queries.
