August 21, 2025, 01:45:40 AM *
Author Topic: Fuel gauge stuck  (Read 4690 times)
Plum57
1957 FE
« on: November 19, 2015, 03:20:57 PM »
Hi.   I have half a tank of fuel and recently changed to a new  fuel pump replacing the vaccum  fuel pump which was leaking fuel.   I have electric wipers so no need for the vacuum line.   Somehow the fuel gauge is now stuck showing full.     The gauge working fine prior to replacing the pump.  Q. Does the vacuum line have anything to do with this?
I don't think it is electrical or fuel sender ...it is something I have done replacing the fuel pump.
I do have an inline fuel filter from pump to carby which is on top of the motor so not sure about this?
Any suggestions greatly appreciated
Peter
Geoff_K
The 2 BAY s
« Reply #1 on: November 19, 2015, 05:43:32 PM »
The fuel pump is a 'mechanical' device, and is 'completely isolated' from the electric 'fuel gauge dash unit & associated in tank sender unit.
Your problem with the gauge is co-incidental.
Check your wiring for 'loose connections, shorts etc', or let your trusty auto-electrician check it out.
A lot of original gauges & tank units are now (after 50 years) somewhat tempermental / faulty, and if this is case take BOTH units as a set to an Auto-instrument and they can nearly always fix it for you.
Geoff_K
Plum57
1957 FE
« Reply #2 on: November 19, 2015, 06:12:22 PM »
Thanks Geoff.
Temperamental thing I thought it may have been something I upset changing the fuel pump.   I will have to do the auto elec as you suggest.   Appreciate your reply
Peter
collecta
« Reply #3 on: November 19, 2015, 09:50:16 PM »
 Hi Peter, did the vac fuel pump still have the original braided fuel line? It sounds like you have an earthing issue try earthing out the sender body to boot floor or the like with a piece of wire and take note what the gauge does.
Scott
Plum57
1957 FE
« Reply #4 on: November 20, 2015, 02:06:08 PM »
Hi Scott.
Yes I still had the braided fuel line to the vaccum fuel pump but now removed for a fuel hose.   I am also replacing steel fuel line from pump to carby brand new.
I will look at the wiring...bit of electrical tape over the years hiding things.
I will see if that get the gauge moving.
Peter
collecta
« Reply #5 on: November 20, 2015, 05:02:45 PM »
 No worries the braided line is actually a factory body to engine earth point.
Scott
Plum57
1957 FE
« Reply #6 on: November 20, 2015, 07:40:56 PM »
That's very interesting because the braided line was removed and straight after the gauge goes to the right.   There are a number of threads on the forum with quite a few owners experiencing this issue.   Frustrating not having tell tale tank guide for fuel.
I need to check the sender to gauge wiring / loose connections / earth .   Braided line earth to engine point is now fuel hose non metal to fit a inline fuel filter before the pump.
Also
I have found the electrical diagram colour coded wiring on photo bucket loaded up as a link on the forum....so much better than the manual.
Peter
Page created in 0.023 seconds with 16 queries.
