August 20, 2025, 10:31:59 PM *
Author Topic: Lifting Grey engines  (Read 6597 times)
Fraze
« on: October 24, 2015, 02:30:16 PM »
Has anyone tried lifting grey motors using a bit of chain bolted between the two rocker cover studs? I used to lift BMC engines this way and it is easy, maybe greys are too heavy? Love to know, cheers, Fraze
« Reply #1 on: October 24, 2015, 06:40:28 PM »
I Don't recommend it, the studs bend very easily. I have used a chain from the rhs top gearbox bolt to one of the front manifold bolts with success.
fink
« Reply #2 on: October 26, 2015, 04:23:46 PM »
I have a lifting tool you can borrow anytime!  Grin
REDMR2RED
FC Ute's d'best
« Reply #3 on: October 26, 2015, 10:28:21 PM »
Grey motor lifting tool
1959 FC Holden Ute
Fraze
« Reply #4 on: October 27, 2015, 07:32:30 AM »
Thanks for the replies. I did try my engine lift/leveller on my spare engine and there was no problem. I set the two lifting chains so that there was a direct vertical pull, not sideways and it did the job without bending or damaging the studs.
However I think I will try to borrow a proper lifting tool as RedMR2Red pictures, and make one for myself.
Fraze
« Reply #5 on: October 27, 2015, 07:36:09 AM »
Hey Fink, Where are you based? I'd like to borrow your engine lifter and make one for myself. Thanks, Frazer
« Reply #6 on: October 27, 2015, 11:46:19 AM »
Mostly I lifted with a chain between the rocker studs . But that was back when parts [even motors were common] but couldn't you simply use a piece of angle drilled and placed between and under the chain to hold the studs apart. Just a thought .
« Reply #7 on: October 27, 2015, 04:28:11 PM »
Problems occur when the gearbox is lifted out with the engine (most times it is) as the engine takes on quite an angle. Even with a vertical start lifting the engine, there is quite an angular pull when the engine is at 45 degrees.
« Reply #8 on: October 29, 2015, 06:48:26 PM »
Yeah understood ,but that can work to your advantage if you don't want to take your grille out . They are not a heavy motor ,so with a little thinking and some physics [and maybe a rope or your children's skateboard]  its not really an issue .
Fraze
« Reply #9 on: October 30, 2015, 07:43:42 AM »
Hey Fink, can you let me know where you are located please?  I would like to borrow the lifting tool as you offered so I can make one for myself. Thanks, Frazer
« Reply #10 on: October 30, 2015, 07:50:48 AM »
Best give Gaz (Fink) a call.
0402713418
Page created in 0.044 seconds with 16 queries.
