August 27, 2025, 06:55:57 PM *
Pages: 1 ... 17 18 [19]   Go Down
Author Topic: Cams FC Resto  (Read 215079 times)
camxsmith
« Reply #360 on: August 23, 2021, 02:19:11 PM »
Repaired a couple of spots over the weekend. Both near the drivers side A Pillar.
(sorry light was not good)
Cut the rust out and put on some rust convert
Weld thru primer under new piece test fitting
Weld it in coat with primer
Another bad spot under the front guard
Cut out
Make a new piece
Weld it in and coat with some primer
camxsmith
« Reply #361 on: August 28, 2021, 08:28:58 PM »
Another little bit done today...
« Reply #362 on: August 28, 2021, 08:30:17 PM »
That is super neat Cam. Well done as usual
camxsmith
« Reply #363 on: October 01, 2021, 10:52:43 AM »
New ignition barrel location moved from the old dash panel, because of the new dash panel design.
camxsmith
« Reply #364 on: October 28, 2022, 07:59:17 PM »
Hi All, its been a long time .. Hope all are doing well. I'm still on the forum, and still love the posts.  Caught up with Brett_f today grabbed some gems..  Front spears and tail light surrounds.. Has got my FC blood flowing again, and wanting to do more on the car again.  So I have some pics and posts to come soon.
camxsmith
« Reply #365 on: October 31, 2022, 09:12:06 AM »
Some Pics of the floor coated in the kbs products
Added a plate in the roof for the sun visor.
Formed a plate to match the roof line
Used a self tapper to hold it in place
Spot welded it in place
Used some sealer and rivet nuts to hold the center bar in place
Mal W
« Reply #366 on: October 31, 2022, 10:14:48 AM »
Looking great Cam.
Good idea with the sun visor bracket strengthening. Think I may also do that with mine while its in bits.
Mal
Malcolm WHITTAKER
camxsmith
« Reply #367 on: November 11, 2022, 10:36:55 AM »
Accelerator pedal completed.  Started with a commodore pedal, and fabricated a bracket and mount plate, using the original bushes and spring.
Lick of paint ready to bolt in
camxsmith
« Reply #368 on: November 11, 2022, 10:43:14 AM »
Weber 34 adm accelerator mount bracket. Started with a lot of lines and measurements, making sure cable will not hit the air cleaner and come over rocker cover    Huh
Drilled holes, folded on the lines and added some weld for extra strength
Final test run
Lick of paint and happy with its look and how it works
camxsmith
« Reply #369 on: November 11, 2022, 10:48:07 AM »
Finishing off the dash for the altered gauge panel.
Cuts made
Replacement lip hammed out
Welded in and cleaned up, happy with the result
« Reply #370 on: November 11, 2022, 10:57:48 PM »
-1
I just did a cable setup on the 179 X2 in my FB ute. The jugs bolt straight on the manifold which makes for very little clearence to the manifold. Also I'm running a tall tappet cover for roller rockers clearence, exacerbating the issue.I ended up setting it up to pull down on the manifold side. Using a hx v8 cable. I use the original pedal, extending to a 60mm radius, with outer bracket sandwiched between brake union and subframe leg.
« Last Edit: January 06, 2024, 03:48:37 PM by RET » Logged
camxsmith
« Reply #371 on: March 17, 2023, 03:35:42 PM »
Been welding holes up in the firewall, looking at a heater option and making a fuse block holder to go under the dash
camxsmith
« Reply #372 on: January 06, 2024, 10:00:13 AM »
Hi all  happy new year.  Being working on upgrades to the wiper arms and pivots, trying to get rid of the slop for a smoother running wiper. First pulled them apart
Next was to lathe up some new bushes, two in each.
Removed the small arms and the ends of the loger arms
Replaced them with a bolt to cater for the ball joint ends
Finished product , I can now adjust the throw of the wiper by lengthening the small arms
« Reply #373 on: January 06, 2024, 12:46:27 PM »
Well done!
Jolls
Online Online
« Reply #374 on: January 07, 2024, 03:28:53 PM »
Thanks, that is such a neat solution to the problem. I will add that to my list of jobs to do.
Jolls
Cheers n Beers
Jolls
« Reply #375 on: January 08, 2024, 01:23:08 PM »
Nice work on the wiper arms Cam
camxsmith
« Reply #376 on: January 10, 2025, 09:15:10 AM »
Hi its been a while will give you an update
Removed all rust and painted the internal roof
Cleaned up the parcel shelf add some speaker holes, and painted in etch primer
With my heater solution. I have made a funnel to flow the air in to the top of the heater. Then altered the air flow input for the heater so they both could bolt togeter.  And had to move the vent open/close lever to the left some to allow for the heater. The heater body is cut up HR holden heater.
Using universal vintage air demister vents/ducts and home made braket welded on to hold the braket in place.
More updates to come soon.
Jolls
Online Online
« Reply #377 on: January 10, 2025, 02:03:06 PM »
Very tidy work = great inspiration for those of us that are behind you in the restoration process.
Cheers n Beers
Jolls
Pages: 1 ... 17 18 [19]   Go Up
Page created in 0.024 seconds with 17 queries.
