July 18, 2025, 02:23:07 PM *
Author Topic: Sta-Put Gear Lever Lock  (Read 2718 times)
« on: June 02, 2015, 08:26:56 AM »
Just after some advice. I have a FE/FC gear lever lock with no rubber covering over the bracket, as well as one from an (unknown) later model that has the rubber. It isn't perished, but it's a bit brittle.
Any tips on the best approach to get it off one and onto the other in one piece? The chances of finding another rubber seem pretty remote...
DJ
« Reply #1 on: June 02, 2015, 11:29:43 AM »
I've had success using the 'Rubber Magic' spray on some old rubber components I've had to reuse. Applied it a few times over a couple of days, WD40 to help release any bond between rubber & metal, some added warmth also helped.
0417 270 315
« Reply #2 on: June 02, 2015, 01:53:09 PM »
Thanks Dave, will give that a try.
Cheers RET
« Reply #3 on: June 03, 2015, 06:44:42 AM »
G'day RET,
I had some success replacing the "tube" parts of the rubber using bicycle inner tubes. Slide a length of inner tube into the Staput tube, then invert (fold) the ends back over. Looks quite original. The "bracket" part of the rubber though is another story - have tried some fit and fiddle with inner tube, but can't get it looking right.
« Reply #4 on: June 03, 2015, 07:09:33 AM »
Thanks Harv. In my case the inner rubber (also from the donor) is in pretty good order, and slid straight in. But that's a good tip about using a bicycle inner tube that might help someone else reading this thread.
Page created in 0.032 seconds with 17 queries.
